Dual exhaust - Ford Truck Enthusiasts Forums
Dual exhaust
Old 08-25-2012, 03:41 PM
77 2wd 77 2wd is offline
77 2wd is starting off with a positive reputation.
Dual exhaust
Putting a 429 in my truck, alrighty got a set of dual headers, i need advice on what kind of dual exhaust to run, any suggestions on muffler glass packs all those goodies?
Old 08-25-2012, 04:05 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
2.5" pipe, X or H pipe about a foot behind the collectors (if you can fit it) if not, true duals are just fine too, free flowing muffler/glasspack, terminate it to your liking e.g. at the rear wheels, under the bumper, etc.
Old 08-25-2012, 04:19 PM
Quote:
alright, so when i go to my muffler shop tell em 2.5" pipe with an X pipe preferably behind the collectors, and glasspacks? ive heard good things about flowaster 40's, is that what they call a certain muffler?
Old 08-25-2012, 04:42 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
No. Glasspacks are just like the word says. It's made with a perforated inner tube wrapped with fiberglass packing to absorb the sound waves. Then it is inserted in a steel tube. Then the outer tube's the ends are spun down and welded to the inner tube. More accurately, they should be called "glass-packed".
Flowmaster 40s are referred to as "welded mufflers" with a thick outer casing. Inside, the exhaust flow and sound waves are deflected with baffles for sound tuning and sound absorption. Sound waves that are 180 out of phase and meet each other in opposing directions cancel each other out. Flowmaster designs their mufflers to cancel out certain frequencies while maximizing flow given the application.
If you can weld, buy Speedway Motors' mandrel bent tubing kit and fab it yourself.
Old 08-25-2012, 04:49 PM
460 FORD MAN's Avatar
460 FORD MAN 460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
I got a 460 with dual glasspacks and they sound loud and mean.
Old 08-25-2012, 04:56 PM
how much would that cost?? and should i go with glasspacks or flowmaster 40's ive heard great things about both!!
Old 08-25-2012, 05:01 PM
HIO Silver's Avatar
A 2.5-inch mild steel kit is only $140 from Speedway... It's like $220 from Summit... save some moolah and apply what you save towards Flowmaster 40s. Around $90 apiece. Alternatively, I recall Summit just came out with Flowmaster-looking welded mufflers for about $30 each.
Personally, I avoid glasspacks because the fiberglass packing crumbles over time and all ya end up with is a 5hitty sounding ride. Relatively inexpensive yes but crappy quality.
YOU have to decide what is best for you. I went with Moroso Spiral Flows... $55 each, compact, no fiberglass, and no moving parts like Dynomax's VT muffler.. Btw, stay away from the VTs.. it's a stoopid gimmick.
Old 08-25-2012, 05:19 PM
Thanks!
Old 08-25-2012, 06:08 PM
Hahaha, thanks HIO!
But you have to admit they sound good while they last!
Old 08-25-2012, 07:19 PM
HIO Silver's Avatar
Quote:
Originally Posted by 460 FORD MAN View Post
Hahaha, thanks HIO!
True... while they last.
Old 08-25-2012, 08:03 PM
410F-100's Avatar
410F-100 410F-100 is offline
410F-100 is starting off with a positive reputation.
flowmaster is deffinatly the way to go... there are also a couple different types flowmaster 40, the super 40s will be louder than the deltas... check their sight,they have a few vids for a general idea.
flowmaster alos highly recomends a Hpipe over the Xpipes for bigger motors. X pipes tend to benefit smaller motors like 4 bangers...
Old 08-25-2012, 09:47 PM
jgavac's Avatar
jgavac jgavac is offline
jgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to all
I lean towards glasspacks over flows. I personally think the flows sound a little odd on 460 trucks, but thats just me. If my truck had a smaller engine, say 351 or 302 I might have gone with flows.
$0.02
Jameson
Old 08-25-2012, 09:50 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
Personally I prefer the flowmaster super 40's. Love the sound.
Old 08-25-2012, 10:10 PM
410F-100's Avatar
glasspacks do sound awsome on just about everything, but the glass tends to break down. i like the idea of baffles over glass. and stainless, never buy mufflers again!
i have a vw w/ a built vr6 that has a single delta 40 and a long resonater, but still fairly loud,and when it backfires its a piggy attracting bang!
Old 08-26-2012, 12:42 AM
As far as glasspacks go it's like anything else, you get what you pay for, some are better than others.
I've been running "Jones PowerPack" glasspacks from "Full Line Exhaust" for over 8yrs (link below) and they've yet to blow out and still sound great.
They're 14 gauge aluminized steel, perforated core, which holds the 'glass' in better than a louvered core glasspack does, the perforated core also creates less back pressure.
They're also made in the USA.
Full Line Exhaust - Glasspacks
Duals exhaust , who has them? Jaaaaaaackman 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-28-2016 10:19 AM
dual exhaust and dual inlet/outlet muffler edreckers Performance & General Engine Building 3 08-11-2015 05:13 AM
True dual exhaust akbash 6.2L V8 7 06-22-2014 08:16 PM
diesel Dual Exhaust X nitrojas Excursion - King of SUVs 5 07-07-2006 02:55 PM
true dual exhaust Pastmaster 1997 - 2003 F150 3 03-23-2000 11:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
