You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey guys, the 223 is beat up bad wore out, I'm ready to make the big move to a V-8. Will ya'll please help me with which V-8 to swap in? I really just want a 302 to gain better access to parts, and I don't know which years' motors will drop in and bolt up to my 4 spd. I guess it is a t-98. HELP! thank yall, I will literally do what the forum suggests. This 60 f250 is a beater my wife will pick up hay/feed in. Don has a few pics if interested. have a great weekend guys
The only engine that will just drop in, is another 223. Even with a Y block V8 you need a different bellhousing and front mount. There are mounts that lets you put a 302 in, but don't think the trans will work.
A few years back I put a 302 in a '40 ford 1 1/2 ton. It came from a '70s 1/2 ton so I just used the 4 spd trans that it was already bolted to. I even used the engine mounts and the trans crossmember from the donor with some alterations. It was really quite simple and it was my first engine swap. Some things I read made an issue about the oil pan and axle clearance, but mine being a big truck had plenty of height so it didn't matter. Just jump in, it's really fun and challenging, and that 302 made a great truck out of that '40. Just for the record, I didn't pull the flathead v8 out of the '40. The PO had already done that and stuck a 401 cu in Buick nailhead in it with an auto trans. Total hillbilly job of it and when I got it running you could hear it knocking from a 1/2 mile away. Good Luck!
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
thanks GB, I would like to do just that- drop a set up complete like that- I guess I would have to cut my driveshaft down tho- thanks for the courage/advice
On my fridge truck diesel conversion I got lucky. The '92 sterling rear axle had a bigger driveshaft than the '59, so I ran in some spacers (ok, they're 1/4-20 stove bolts) about a foot apart and telescoped the two shafts together. It was a tap together with a brass hammer fit, and it allowed me to get the perfect length, right in place on the truck. The ring at the weld joint is a piece of 2 1/2" pipe that fit nicely onto the smaller shaft, so I welded it in place and plugged the splines into the tranny, let out the clutch and I had a 4 speed lathe. I used the angle grinder to turn down the OD of the pipe until it fit nicely into the bigger driveshaft. I took a freeway trip a couple weeks ago and hit 65 a lot of the time and no vibration. I guess I could have gotten it done at a shop for a hundred bucks or so, but that's another trip or two off the island. I figure about the worst that could happen is the weld breaks and the two shafts just spin within each other and I coast to a stop.......I await the report on your engine swap.
__________________
Thanks GB that was interesting- I'm a big fan of "gettin it done" that was great- not sure what is gonna happen with my 60- just rebuilt the carb- still does the same thing- idle for 2 min. then cough, cut off. Sure would like to get a new carb- I'll keep ya posted
