axle nut torque specs - Ford Truck Enthusiasts Forums
Old 08-24-2012, 03:26 PM
jeep_guy48's Avatar
jeep_guy48 jeep_guy48 is offline
jeep_guy48 is starting off with a positive reputation.
anyone know what the torque specs are for the front axle nuts that hold the hub on. all i have found so for is 50 lbs. in and back off a 1/4 of a turn and then the outer to 160. is this correct???
Old 08-24-2012, 03:27 PM
jeep_guy48's Avatar
sorry i forgot to mention that it has the d50 with manual hubs.
Old 08-24-2012, 07:00 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I'm not complete help, but I just put my 50 back together. I however have auto hubs, and I tightened my single nut to 50 and backed off 1/4 turn, then tightened a hair more. My directions say to tighten to 16 inch pounds, that aint much and I have no wrench like that so I tightened a hair after backing off 1/4 turn.
From what I came up with on this link you are right on the locknut.
1996 Bronco/F-Series
Old 08-25-2012, 04:56 AM
hookedondiesel hookedondiesel is offline
hookedondiesel is gaining momentum as a positive member of FTE.
Quote:
Correct, actually 55 and 166, but your figures are ok.
Old 08-26-2012, 09:13 AM
jeep_guy48's Avatar
thanks for all the help
Need some Torque specs Deluxe06 1999 - 2003 7.3L Power Stroke Diesel 5 11-07-2016 05:09 AM
Axle nut torque stormer426 1947 and Older Ford Trucks 2 07-03-2012 10:13 PM
torque specs for axle hub nuts Eagle Transit Brakes, Steering, Suspension, Tires, & Wheels 0 01-22-2011 11:27 AM
rear axle nut torque spec RoughIdle Clutch, Transmission, Differential, Axle & Transfer Case 2 12-19-2009 08:01 PM
Bearing nut torque spec. 76 1 ton. savagefan 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-24-2006 06:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
