P0172 and p1648
P0172 and p1648
Got p0172 and p 1648 from my super chip code reader....1and2and reverse are good , very sluggish Start in drive and od light flashes....just replaced tc and have a hot ground wire that was attached to tranny but is now disconnected for truck to run or 20afuse blows when ground wire bolted on???......do I need a new pcm? Help....
Are those the rite codes ? I don't see them in our list
* P1111 System Pass (No DTCs Available)
* P0107 BARO Circuit Low Input
* P0l08 BARO Circuit High Input
* P0112 IAT Sensor Circuit Low Input
* P0113 IAT Sensor Circuit High Input
* P0122 Accelerator Pedal Sensor Circuit Low Input
* P0123 Accelerator Pedal Sensor Circuit High Input
* P0197 EOT Sensor Circuit Low Input
* P0198 EOT Sensor Circuit High Input
* P0220 Throttle Switch B Circuit Malfunction
* P0221 Throttle Switch B Circuit Performance
* P0230 Fuel Pump Relay Driver Fail
* P0231 Fuel Pump Relay Driver Circuit Failure
* P0232 Fuel Pump Relay Driver Failed Off
* P0236 Turbo Boost Sensor A Circuit Performance
* P0237 Turbo Boost Sensor A Circuit Low Input
* P0238 Turbo Boost Sensor A Circuit High Input
* P0261 Injector Circuit Low - Cylinder 1
* P0262 Injector Circuit High - Cylinder 1
* P0263 Cylinder 1 Contribution/Balance Fault
* P0264 Injector Circuit Low - Cylinder 2
* P0265 Injector Circuit High - Cylinder 2
* P0266 Cylinder 2 Contribution/Balance Fault
* P0267 Injector Circuit Low - Cylinder 3
* P0268 Injector Circuit High - Cylinder 3
* P0269 Cylinder 3 Contribution/Balance Fault
* P0270 Injector Circuit Low - Cylinder 4
* P0271 Injector Circuit High - Cylinder 4
* P0272 Cylinder 4 Contribution/Balance Fault
* P0273 Injector Circuit Low - Cylinder 5
* P0274 Injector Circuit High - Cylinder 5
* P0275 Cylinder 5 Contribution/Balance Fault
* P0276 Injector Circuit Low - Cylinder 6
* P0277 Injector Circuit High - Cylinder 6
* P0278 Cylinder 6 Contribution/Balance Fault
* PO279 Injector Circuit Low - Cylinder 7
* P0280 Injector Circuit High - Cylinder 7
* P0281 Cylinder 7 Contribution/Balance Fault
* P0282 Injector Circuit Low - Cylinder 8
* P0283 Injector Circuit High - Cylinder 8
* P0284 Cylinder 8 Contribution/Balance Fault
* P0301 Fault Cylinder A-Misfire? Detected (CYL 1)
* P0302 Fault Cylinder B-Misfire? Detected (CYL2)
* P0303 Fault Cylinder D-Nlisfire? Detected (CYL 3)
* P0304 Fault Cylinder E-Misfire? Detected (CYL 4)
* P0305 Fault Cylinder F-Misfire? Detected (CYL5)
* P0306 Fault Cylinder G-Nlisfire? Detected (CYL 6)
* P0307 Fault Cylinder C-Misfire? Detected (CYL 7)
* P0308 Fault Cylinder H-Misfire? Detected (CYL 8)
* P0340 CMP Sensor Circuit Malfunction
* P0341 CMP Sensor Circuit Performance
* P0344 CMP Sensor Circuit Intermittent
* P0360 Glow Plug Circuit Malfunction
* P0381 Glow Plug Indicator Circuit Malfunction
* P0460 Fuel Tank Level Indicator Circuit Malfunction
* P0470 Exhaust Back Pressure Sensor Circuit Malfunction
* P0471 Exhaust Back Pressure Sensor Circuit Performance
* P0472 Exhaust Back Pressure Sensor Circuit Low Input
* P0473 Exhaust Back Pressure Sensor Circuit High Input
* P0476 Exhaust Pressure Control Valve Maffunction
* P0476 Exhaust Pressure Control Valve Performance
* P0478 Exhaust Pressure Control Valve High Input
* P0500 Vehicle Speed Sensor (VSS) Malfunction
* P0503 Vehicle Speed Sensor Noisy
* PO541 Manifold Intake Air Heater
* P0542 Manifold Intake Air Heater
* P0560 System Voltage Malfunction
* P0662 System Voltage Low
* P0563 System Voltage High
* P0666 Cruise 'On" Signal Malfunction
* P0566 Cruise "Off' Signal Malfunction
* P0667 Cruise 'Resume' Signal Malfunction
* P0668 Cruise "Set' Signal Malfunction
* P0669 Cruise "Coast' Signal Malfunction
* P0571 Brake Svdtch A Circuit Malfunction
* P0603 Internal Control Module KAM Error
* P0605 Internal Control Module ROM Error
* PO606 PCM Processor Fault
* P0640 Manifold Intake Air Heater
* P0670 Glow plug control circuit malfunction
* P0671 Glow plug #1 circuit failure
* P0672 Glow plug #2 circuit failure
* P0673 Glow plug #3 circuit failure
* P0674 Glow plug #4 circuit failure
* P0675 Glow plug #5 circuit failure
* P0676 Glow plug #6 circuit failure
* P0677 Glow plug #7 circuit failure
* P0678 Glow plug #8 circuit failure
* P0683 Glow plug diagnostic signal communication fault
* P0703 Brake Switch B Circuit Malfunction
* P0704 Clutch Pedal Position Switch Input Circuit Malfunction
* P0705 TR Sensor Circuit Malfunction
* P0707 TR Sensor Circuit Low Input
* P0708 TR Sensor Circuit High Input
* P0712 Transmission Fluid Temp. Sensor CKT Low Input
* P0713 Transmission Fluid Temp. Sensor CKT High Input
* P0715 TSS Sensor Circuit Malfunction Fault
* P0717 TSS Intermittent Failure
* P0718 Noisy TSS
* P0720 OSS Sensor Circuit Malfunction
* P0721 Noisy OSS
* P0722 OSS Intermittent Failure
* P0732 Gear Two Ratio Error
* P0733 Gear Three Ratio Error
* P0741 TCC Circuit Performance
* P0743 Torque Converter Clutch System Electrical Failure
* P0750 Shift Solenoid 1 Malfunction
* P0755 Shift Solenoid B Malfunction
* P0781 1-2 Shift Malfunction
* P0782 2-3 Shift Malfunction
* P0783 3-4 Shift Malfunction
* P1000 OBD 11 Monitor Checks Not Complete. More Driving Required
* P1105 Dual Alternator Upper Fault (Monitor)
* P1106 Dual Afternator Lower Fault (Control)
* P1107 Dual Alternator Lower Circuit Malfunction (Control)
* P1108 Dual Alternator BATT Lamp Circuit Malfunction
* P1118 Manifold Air Temperature Sensor Low Input
* P1119 Manifold Air Temperature Sensor High Input
* P1139 Water in Fuel Indicator Circuit Malfunction
* P1140 Water in Fuel Condition
* P1184 Engine Oil Tamp Sensor Circuit Performance
* P1209 Injection Control System Pressure Peak Fault
* P1210 Injection Control Pressure Above Expected Level
* P1211 ICP Not Controllable - Pressure Abow/Below Desired
* P1212 ICP Voltage Not at Expected Level
* P1218 CID Stuck High
* P1219 CID Stuck Low
* P1247 Turbo Boost Pressure Low
* P1248 Turbo Boost Pressure Not Detected
* P1249 Wastagate Fail Steady State Test
* P1250 Electronic Passive Anti-Theft? System
* P1261 High to Low Side Short - Cylinder 1
* P1262 High to Low Side Short - Cylinder 2
* P1263 High to Low Side Short - Cylinder 3
* P1264 High to Low Side Short - Cylinder 4
* P1265 High to Low Side Short - Cylinder 5
* P1266 High to Low Side Short - Cylinder 6
* P1267 High to Low Side Short - Cylinder 7
* P1268 High to Low Side Short - Cylinder 8
* P1 High to Low Side Open - Cylinder 1
* P2 High to Low Side Open - Cylinder 2
* P3 High to Low Side Open - Cylinder 3
* P4 High to Low Side Open - Cylinder 4
* P5 High to Low Side Open - Cylinder 5
* P6 High to Low Side Open - Cylinder 6
* P7 High to Low Side Open - Cylinder 7
* P8 High to Low Side Open - Cylinder 8
* P1280 ICP Circuit Out of Range Low
* P1281 ICP Circuit Out of Range High
* P1282 Excessive ICP
* P1263 IPR Circuit Failure
* P1284 ICP Failure - Aborts KOER or CCT Test
* P1291 High Side No. 1 (Right) Short to GND or B+
* P1292 High Side No. 2 (Left) Short to GND or B+
* P1293 High Side Open Bank No. 1 (Right)
* P1294 High Side Open Bank No. 2 (Left)
* P1295 Multiple Faults on Bank No. 1 (Right)
* P1296 Multiple Faults on Bank No. 2 (Left)
* P1297 High Sides Shorted Together
* P1298 IDM Failure
* P1316 Injector Circuit/IDM Codes Detected
* P1391 Glow Plug Circuit Low Input Bank No. 1(Right)
* P1393 Glow Plug Circuit Low Input Bank No. 2 (Left)
* P1395 Glow Plug Monitor Fault Bank No. 1
* P1396 Glow Plug Monitor Fault Bank No. 2
* P1397 SYstem Voltage Out of Self Test Range
* P1464 A/C On During KOER or CCT Test
* P1501 VSS Out Of Self Test Range
* P1502 Invalid Self Test - APCM Functioning
* P1531 Invalid Test -Accelerator Pedal Movement
* P1536 Parking Brake Applied Failure
* P1662 IDM EN Circuit Failure
* P1663 FDCS Circuit Failure
* P1667 CID Circuit Failure
* P1668 PCM -IDM Diagnostic Communication Error
* P1670 EF Feedback Signal Not Detected
* P1690 Wastegate Control Valve Malfunction
* P1702 TRS Sensor Intermittent Circuit Malfunction
* P1704 Digital TRS Failed to Transition State
* P1705 TR Sensor out of Self Test Range
* P1711 TFT Sensor Out of Self Test Range
* P1713 TFT Stuck in Range Low-Below? 50'F
* P1714 Shilt Solenoid A Inductive Signature Malfunction
* P1715 Shift Solenoid B Inductive Signature Malfunction
* P1718 TFT Stuck in Range High-Above? 25OF
* P1728 Transmission Slip Error
* P1729 4x4L Switch Error
* P1744 Torque Converter Clutch System Performance
* P1746 EPC Solenoid Open Circuit
* P1747 EPC Solenoid Short Circuit
* P1754 CCS (Solenoid) Circuit Malfunction
* P1760 EPC Solenoid Short Intermittent
* P1780 TCS Circuit Out of self Test Range
* P1781 4x4L Circuit Out of Self Test Range
* P1783 Transmission Overtemperature Condition
[/font][/color]
* P0718 Noisy TSS
* P0721 Noisy OSS
* P1298 IDM Failure
[/font][/color]
