Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-24-2012, 12:15 PM
whiteaddiction whiteaddiction is offline
Garage is empty, add now
whiteaddiction is starting off with a positive reputation.
added a filter to my truck, CEL?
Is there something else that has to be done when adding an inline filter? I just added a FRAM PH8A filter, unhooked the fuel lines from the inlet of the fuel pump in the valley of the engine and jumped it over to my filter. No my computer says lack of fuel pressure?
Any help... Thanks
  #2 (permalink)
Old 09-07-2012, 10:07 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.
timmyboy76 seadooya
Quote:
Any help... Thanks
Having a hard time visualizing this one, bud. You got the fuel bowl in front of valley, but the pump itself is down below d/s door, inside the frame..
__________________
TIM...PAA#113....plenums inserts, hpx, frx, 50 cent, gauges, trans-coolant-oil DIY by-pass systems, H/H mod, DIY WVO system 156k and counting
  #3 (permalink)
Old 09-07-2012, 11:04 AM
Quote:
The only fuel pump I have is the factory one on the top of the engine. there is no pump on the frame.
I put a FRAM PH8A filter inline before the factory pump, but it seems to be too hard for the pump to pull the fuel threw the FRAM filter.
  #4 (permalink)
Old 09-08-2012, 10:07 AM
timmyboy76's Avatar
timmyboy76 seadooya
apologize, was thinking that you had a 99-03 7.3 truck..
I'd say, remove the filter and see what happens. Maybe, the filter is too small of micron rating. I wouldnt put anything under a 30micron, before pump, without a "helper" pump.
__________________
  #5 (permalink)
Old 09-10-2012, 07:09 AM
rufushusky's Avatar
rufushusky rufushusky is offline
rufushusky has a good reputation on FTE.rufushusky has a good reputation on FTE.
Any help... Thanks
How did you route the hose? The lines might have kinked causing too much restriction. Secondly the PH8A is an oil filter...not a fuel filter. Different media and micron ratings are different. Fuel filters are single pass, oil filters are multipass. I would dump the fram IMHO.
__________________
2002 F-350 ECLB SRW 4WD 7.3 4R100, 08 diff cover, RiffRaff 6637, HPX, 203* T-Stat, Stancor Relay, Mile Marker Hubs, 6.0 trans cooler
  #6 (permalink)
Old 09-10-2012, 02:11 PM
Quote:
I dont know what single or multipass means?
There was deff not a kink in my hose. But the hose I used might be too soft and could have sucked close? I was wondering if I should put it after the pump?
Anyway the truck has been running great since I took the filter off, I was just trying to get something a little more better and cheaper for filtering.
  #7 (permalink)
Old 09-10-2012, 02:25 PM
rufushusky's Avatar
Per SAE J1985 single pass filtration efficiency measures how efficient a filter stop particulates at one pass of the fluid through the filter.
Multi-pass measures the efficiency when the fluid gets circulated multiple times.
Single pass ratings make more sense with a fuel filter since at least some of the fuel will only see the filter once, while oil (or trans fluid or coolant etc etc) will see the filter many times in the relatively closed environment.
A better bet would be a Baldwin BF1311 filter head and a BF1212 fuel filter pre-pump.
Baldwin Filter FB1311 Fuel Filter Base
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
