Lifter Collapse ?
Lifter Collapse ?
2004 With 03 engine. Started it up one morn with loud rpm related clicking in pas side of engine. We have a local guy that does a lot of 6.0 repair work took the truck to him and he is telling me that one of the lifters is collapsed. He is telling me we can replace all the lifters with out pulling engine and total disasemble of engine, is this possible? and is the collapse of a lifter common I havent read much about it on here. Truck actuly still runs fine and no codes show up on scan.
No experience with this but I'll offer an opinion . Did he pull the valve cover? I have seen several posts featuring bent rocker arms and pushrods. I think that's much more likely. Next most common is losing the roller off the end of the lifter. That takes out the cam in a few revolutions. It's my understanding the engine has to be torn down to get the cam out (even the crankshaft and pistons) and the
Lifters are literally THE last thing to come out. Hope it's a rocker arm or pushrods.
I guess it's conceivably possible to change all the lifters with the engine in the truck, but I'm not sure it would be much faster than just pulling the engine. The branch tube covers at least the rear two lifters on each side, and to remove the branch tube you have to remove the rear cover, which can be done with the engine installed by sliding the trans back or removing it. But space is going to be tight, he might work faster with the engine in the open or the cab gone. Maybe Cheezit or M-chan can chime in, I know they each have different opinions on the benefits of removing cab to get the heads off, maybe the have opinions on pulling the engine or not.
If the cam is damaged you're screwed, the crankshaft has to come out to replace it so you're looking at a full rebuild.
IDI guy
02-19-2014 10:12 PM
black58
06-04-2006 09:21 PM
allford86
07-10-2005 08:02 PM
