Cummins swap - Ford Truck Enthusiasts Forums
Cummins swap
Old 08-24-2012, 09:19 AM
Brianmb Brianmb is offline
Brianmb is starting off with a positive reputation.
Cummins swap
I'm sure this has come up before but is it possible to drop a dentside super cab and bed onto a dodge chassis which has the cummins engine, driveline etc. already to go?
Old 08-24-2012, 11:13 AM
keiths78f150's Avatar
keiths78f150 keiths78f150 is offline
keiths78f150 is gaining momentum as a positive member of FTE.
I have seen a cummins dropped into a ford, but not a ford body onto a dodge chassis. You would have to check frame width, adjust body mounts, etc. It would require quite a bit of fabrication. It would be easier to drop the cummins into the ford.
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
it's about as much work as putting the cummins in the ford.
Posted these before a few times for this same question, but here's a crew cab on a dodge 2004 reg cab, long bed frame (I think). Been years since I talked with the guy so I can't remember. He wanted to use the dodge body mounts so he stretched the front end of the truck. Looks goofy to me.
Old 08-26-2012, 11:27 PM
punkrockpilot's Avatar
punkrockpilot punkrockpilot is offline
punkrockpilot is gaining momentum as a positive member of FTE.punkrockpilot is gaining momentum as a positive member of FTE.
they did that on POWERBLOCK truck show on spike a while back. They found a Dodge 1997 extra cab long bed and was able to make it work but had to do new body mounts and move the engine about 5" back. But I agree that it would be better to use a ford chassis and mount the cummins on it.
Old 08-27-2012, 05:28 AM
spikinfool05's Avatar
spikinfool05 spikinfool05 is offline
spikinfool05 is starting off with a positive reputation.
you deserve a mopar free truck
Old 08-27-2012, 05:51 AM
77 2wd 77 2wd is offline
77 2wd is starting off with a positive reputation.
or just throw a strong healthy 460 in there
Old 08-27-2012, 09:17 AM
kbrenner536 kbrenner536 is offline
kbrenner536 is starting off with a positive reputation.
79 crew on a extracab longbed frame.
Old 08-27-2012, 02:09 PM
Quote:
Why? Cummins has more power AND gets about twice the mileage
Old 08-27-2012, 08:07 PM
quadrazer's Avatar
quadrazer quadrazer is offline
quadrazer is starting off with a positive reputation.
Quote:
Yep. It was on the show 'Trucks', and it was called Project Super Dually. Very extensive fab work with the core support, dash, steering column. ect. A long and labor intensive project. I believe they have 9 individual episodes so far, dedicated just to that project.
Old 08-28-2012, 04:49 PM
And I think all the episodes can be found online still. I've watched most of them, but not all.
Again - there is a bit of fab either way you go. So pick if you want to make cab/body mounts or motor/trans mounts.
Old 08-28-2012, 07:09 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
I dont really get it... if thats what you want just get an early dodge... if you want a ford keep the ford and swap the motor. personally if I was gonna be swapping bodies to a late model frame, which is a lot of work, I'd go with one of the older body style trucks. Not much of an advantage to swapping frames from a 70's ford to a 90's dodge. similar axles, both ladder style frames, etc. Now, if you are starting with an old body like a 50's one, then the later frame gives you all kinda of upgrades. and the body is more iconic. maybe makes it worth the extra work.
Old 08-28-2012, 07:22 PM
kobaltblue's Avatar
kobaltblue kobaltblue is offline
kobaltblue is gaining momentum as a positive member of FTE.
What an unlimited budget can do to a vehicle....
Put a IDI in it,There cheap easy as hell to work on and with a turbo can pretty much keep up with a cummins.
Old 08-29-2012, 06:29 AM
Blackfoot Big Block Blackfoot Big Block is offline
Blackfoot Big Block is starting off with a positive reputation.
This has nothing to do with the OP's post, bit it's an interesting anecdote:
The late casino magnate William F. Harrah was also an auto enthusiast. He built a huge collection of antique cars, sports cars, etc. (You can see many of them at the National Auto Museum in Reno, NV).
Mr. Harrah owned a casino in Reno and another at Lake Tahoe, and understandably had to make frequent trips between the two casinos. He needed a 4x4 in the winter months and was unhappy with the performance of his Jeep Wagoneer...
The story goes he approached Enzo Ferrari about building him a 4x4 Ferrari but was turned down. He had a bunch of top-notch mechanics employed working on the various vehicles in his collection so he got them to build him a "Jerrari"; a Ferrari powered Jeep Wagoneer.
The first version was a 1969 and had all new front end bodywork. The second one was a 1976 Wagoneer and his guys stretched the front end sheet metal. From the outside you have to look pretty closely to see something's amiss (if you don't catch the Jerrari emblem). I'll bet you can find a story about it if you Google "Harrah's Jerrari "or something like that.
Old 08-29-2012, 12:23 PM
Quote:
With a turbo and a lot of work they can almost be a distant second to a stock, gen 1 cummins.
It's about the same amount of work, so why not go with the better option from the start?
I've heard about it/them. Should be some info somewhere online.
And since we are on the off-topic bit. Anyone ever seen the Lamboghini "SUVs"? Kind of like a crazy hummer. Built for Saudi military or something. Used to be one on the island here and my uncle (does a lot if HIGH end cars) had a customer or 2 with one. They are crazy! And thinking about it now - I've seen 3 of them in person in my life. That's 3 more than most people ever will & probably 2/3 of the total quantity of them in the US - maybe north america! Living near the annoying yuppies in Newport Beach does have weird perks from time to time
Old 08-29-2012, 05:09 PM
husker77's Avatar
husker77 husker77 is offline
husker77 is starting off with a positive reputation.
Quote:
Ya I remember when those came out, there were a few magazine articles on them. They seemed to be fairly capable 4x's. Lamborghini lm002.
Here is one for sale http://refined-marques.com/lamborghini-Lm002-4x4/ but evidently the old saying holds true, if you have to ask you can't afford it.
Now that we have completely hijacked this guys thread.
Cummins Swap 2wd kalebc2 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-12-2015 02:46 PM
Cummins in an F-xxx ?? rlewis581 1999 to 2016 Super Duty 67 01-09-2012 06:17 PM
Cummins in Ford jjsj38 Ford vs The Competition 19 06-06-2010 03:28 PM
Cummins Swap mark460 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 01-13-2010 07:48 PM
84 F350 460ci to 5.9 Cummins Swap DrkZide Engine Swaps 6 07-01-2008 01:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
