why not syn? - Ford Truck Enthusiasts Forums
why not syn?
Old 08-24-2012, 02:39 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
why not syn?
i burn a WMO mix in my rig, and i think i've read that synthetic oil is "bad" to burn in your engine. is this true, and if yes, why, and at what concentration?
most of my used oil supply is dyno, but occasionally i get a gallon or so of syn, and was wondering why its counted as "evil"
Old 08-30-2012, 12:56 PM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
I'm no expert but I do know 2 things about symthetic oils of note. The general consinsious is it doesn't burn as readily. That for instance if you put symthetic in an engine that burns oil it will "burn" less of it, but likely use more cause it's a smaller molicule and leaks past seals more. That said not all symthetics are actually synthetics. Back in the day it was decided after some court battles that highly refined dino oil can be sold as synthetic. So most lower cost "synthetic oils are what's called class 3 synthetics which are highly refined dino oils with synthetic additives. Finding out which is which can be tricky, not something the manufactures make easy to find out. Amsoil and redline I know are true syntheitcs, I think castrol and mobil 1, and pretty sure royal purple, pennzoil, etc aren't.
Just my $.02
Type and Grade of Oil? sandyc 6.7L Power Stroke Diesel 28 11-05-2010 05:07 PM
I'm confused...Do you know??? nico963 6.0L Power Stroke Diesel 6 12-17-2008 10:06 PM
75/90 Syn VS. 75/140 Syn unrulee 1999 to 2016 Super Duty 4 11-04-2008 04:07 PM
Synthetic oil stains harder to clean off the driveway? Big Dave Oil & Lubrication 0 06-19-2004 11:37 PM
5w 40 rotella t syn. Is it worth it? F0rdF0rever 1999 - 2003 7.3L Power Stroke Diesel 12 01-27-2004 05:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
