Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-24-2012, 01:39 AM
joshofalltrades joshofalltrades is offline
1987 Ford E-Series Van
joshofalltrades is gaining momentum as a positive member of FTE.
why not syn?
i burn a WMO mix in my rig, and i think i've read that synthetic oil is "bad" to burn in your engine. is this true, and if yes, why, and at what concentration?
most of my used oil supply is dyno, but occasionally i get a gallon or so of syn, and was wondering why its counted as "evil"
  #2 (permalink)
Old 08-30-2012, 11:56 AM
Opossum Opossum is offline
1989 Ford F-350
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
I'm no expert but I do know 2 things about symthetic oils of note. The general consinsious is it doesn't burn as readily. That for instance if you put symthetic in an engine that burns oil it will "burn" less of it, but likely use more cause it's a smaller molicule and leaks past seals more. That said not all symthetics are actually synthetics. Back in the day it was decided after some court battles that highly refined dino oil can be sold as synthetic. So most lower cost "synthetic oils are what's called class 3 synthetics which are highly refined dino oils with synthetic additives. Finding out which is which can be tricky, not something the manufactures make easy to find out. Amsoil and redline I know are true syntheitcs, I think castrol and mobil 1, and pretty sure royal purple, pennzoil, etc aren't.
Just my $.02
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
