Ckicking sound in cab
I just replaced both my batteries on my 2001 F250 7.3 and then my alternator and now I am experiencing a fast clicking sound when I turn the key and the truck just turns over and doesn't start. This clicking doesn't always happen but if it does, I just turn the key to the off position and then restart - it doesn't do it and the truck starts.
Try to give us at least a teensy bit more to go on in regards to the location of your clicker gremlin so that we can eliminate posibilities.
Pull the cover off under the steering wheel and see if the clicking is coming from the fuse box... or maybe the vertically mounted rectangular box doo dad there on the inside tucked up under by the parking brake ...
Maybe you just got a bad relay..
I hope thats all.
Others will be piping in soon i'd suspect.
Xtof
I hope thats all.
Xtof
Relays will often chatter with low voltage while cranking, but I believe you said the engine cranks fine but won't start, and then if you switch the ignition off and try again it will. Sounds like a bad ignition switch. Without more information (such as voltage readings) my guess is that the switch contacts that supply IGN power in the start position are intermittent.
Chris
Chris
x2 on this.that is the first place to start. there are also relays between the steering column and the radio. 1 is the turn signal relay. mine did what yours is doing but didnt affect it starting
Andy's Beast
25
03-03-2020 01:44 PM
