What gear oil for true-trac
Old 08-23-2012, 06:14 PM
96grimreaper's Avatar
96grimreaper
96grimreaper is offline
I've been searching for hours and haven't come up with a decent answer.
True-trac recommends conventional (non-synthetic) gear oil. I'm not sure a 75W140 non-synthetic gear oil is made so what is everyone running?
My install is gonna be on the first and I'm sure I'll have to order the oil, instead of picking it up at a store. I know there are several people running the True-trac, I need some insight.
Old 08-23-2012, 08:16 PM
Curt's05's Avatar
Curt's05
Curt's05 is online now
Wiser by FTE
90-120 synthetic in mine
Old 08-23-2012, 08:20 PM
96grimreaper
Any noise or lack of operation from running synthetic?
Old 08-23-2012, 10:37 PM
bjm206's Avatar
bjm206
bjm206 is offline
I run 85W140 non-synthetic from Valvoline that I ordered on-line. My local Tractor Supply also stocks non-synthetic 85W140 under their Traveller brand.
The small weight change from stock has not caused any issues in 50K + miles of use including a few winter trips to northern Quebec.
Old 08-24-2012, 12:02 AM
96grimreaper
The VV825?
That's one I've been looking at, only thing that concerns me is the friction modifier that's already in the oil.
Other one I'm considering is the Lucas 85W-140 Heavy Duty but can't seem to find if it's synthetic even though I've read it's conventional.
Old 08-24-2012, 08:59 AM
bjm206's Avatar
bjm206
bjm206 is offline
Yes, Valvoline High Performance Gear Oil 85W140.
The additive has not caused me any issues. The guidance I have seen says you do not need LSD additive but I have not see anything that said to avoid it. They do recommend against synthetic.
This link has some related FAQs for the Truetrac from the manufacturer about 3/4 of the way down the page:
FAQ
Old 08-24-2012, 07:30 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Mine is semi synthetic lube, no noise.
Old 08-25-2012, 10:36 PM
wallz's Avatar
wallz
wallz is offline
I used lucas in mine, and it has now been a few years, and one northern winter, and no issues to speak of. It was the Lucas heavy duty synthetic type.
rs4-380
1999 to 2016 Super Duty
02-08-2015 07:57 PM
jimwilsonmasonry
05-13-2008 08:32 PM
getnbz
01-30-2007 01:18 PM
MBBFord
Offroad & 4x4
16
01-25-2006 07:14 PM
gl0116
03-13-2005 12:10 PM
Quick Reply: What gear oil for true-trac
