My 52 Ford F1 Project - NKY
#136
#137
#138
#140
#141
#142
#143
Slowly but surely coming along... Got some more wiring untangled, installed carb spacer and mechanical fan, figured out I had a bad proportioning valve and swapped it out for a wilwood - but the fun of rebending flaring and chasing leaks when trying to bleed is commencing. Took a "brake" from the frustration and started throwing some odds and ends on.
#144
#146
#150
Temporary in theory, went with a sheet of architectural grade plywood and some leftover deck stain.
Battery is in the Hamm's cooler, got the tail lights mounted still trying to sort out all the wiring with the aftermarket wiring kit... found out a turn signal switch was needed for the brake lights to work, wired the back half of that up and still not working yet...
I checked the brake lights and they work when placed positive to ground, so I will have to get the circuit tester out and find a way to rig the brake pedal down... I am guessing it is my headlight switch, I am only getting 1 positive out besides the feed, and only with headlights on..
