My 52 Ford F1 Project - NKY - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 04-29-2013, 10:21 PM
52 Ford F1 52 Ford F1 is offline
52 Ford F1 is starting off with a positive reputation.
well... after 13 months, it is time to move the truck into my own garage. It has been nice renting a 3 car garage, but as you might expect some of the restrictions and distance from my home make it less than perfect.
This weekend will be spent squeezing a 3 car garage full of parts and tools into a 2 car garage... Got to make it fit.
The bad thing is I know have to get my own garage dirty, and have to clean up my mess in the rental. The good thing, is I can get a little done without jumping in the car and driving 20 minutes each way, and I will be tripping over it until it is done... which should be some motivation.
Next update should be more interesting (aka have pictures)... Got the build book, new gaskets, and plastigauge all in my garage to get the motor checked out..
  #62
Old 04-30-2013, 02:56 PM
Rojak Rojak is offline
Rojak is gaining momentum as a positive member of FTE.Rojak is gaining momentum as a positive member of FTE.
Hey Andrew did you get the old six banger you pulled moved on to a new owner yet?... (please tell me you did!)...
  #63
Old 04-30-2013, 03:09 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
I know how you feel, I moved mine from a warehouse with lots of room to my woodshop, which is only 22' wide by 60' long. I just don't get enough time to work on it so it now spends a lot of time pushed out and covered up. But it is easier to work on it than it was when I had to drive to it. Now I can walk to it.
  #64
Old 04-30-2013, 07:25 PM
still have not sold it... I am trying to trade it at this point since no one has money...
If anyone at the meet was interested I could deliver.
  #65
Old 05-05-2013, 03:38 PM
So close, but so far away..
Lost a few days of working on the truck from moving it out of the place I was renting it.
With the rain today I am focusing on finding a place for all my tools and parts, Shrinking 5 car spaces worth of stuff into 2. Still have another 2 trailer loads to move... and finding a place to hide the trailer... (it folds at least) May end up with a small storage unit, but trying to avoid it.
Now that it is home I hope I can get more hour long sessions in while maintaining the 8 hour sessions to make up for lost time, and the free rent should help too.
Out to the garage... hoping to clean up the engine bay and painting in between organizing.
  #66
Old 05-05-2013, 04:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Looks like nice digs, is that a double-deep garage? IMO time spent making shelves and organizing your work space will pay off big time as you work on the truck. I hate tripping over stuff! (BTW, how many times have you banged your shins on the front frame horns??)
  #67
Old 05-05-2013, 05:55 PM
Quote:
8' 6" extra depth + the truck. It is deep luckily . The back door opens in unfortunately... I am thinking about building shelves along the middle, and agree it would be time well sent. Compressor will go to in the corner by the door. I have been working on the truck more than organizing... and its quitting time after this last coat or etching primer.
Since removing the front and rear bumper I have not hit my shins once. I hit myself real good with the rear bumper, which had a welded on plate for a trailer ball... I think that's what sealed the deal to remove them .
  #68
Old 05-07-2013, 07:49 PM
Got the engine bay cleaned up on cinco de mayo with some help from the scrubbing bubbles and dos equis... the bubbles did some work, but I still had to.
Got the engine bay cleaned up and etch primer on, got the rubber undercoating for the inner fender stuff... Used the prepall after the bubbles, they left a film.
  #69
Old 05-16-2013, 08:13 PM
Finally got to focus some time on the engine... Got it stripped down, and found out a little more about it...
Dropped the oil pan and spun the motor upside down
Noticed a spot on this bearing, I pulled 2 mains and 2 pistons so far...
This is the worst of the piston
Rear main
Crank
Looks like the crankshaft was ground
Pulled the heads
Cylinders did not look too bad, and that's a good thing cuz there is probably not much left to bore.
I am going to be looking to do some upgrades, from the little information I have learned I plan to look for an aluminum intake manifold, upgrading to a 4barrel carb, I am thinking about just replacing the bearings and re-assembling, and maybe upgrading the timing chain if I get talked into it. The cam is the question, keeping in mind it's hopefully gonna be a driver, and I am not expecting a race truck.
I hope to order the parts by the end of next week, but there is tons of information out there on what products are best... I am on a limited budget, but plan to spend around $500 for the upgrades.
I am leaning towards a demon carb, and an intake not designed for too high of RPM. Any advice on carb, intake, etc. appreciated.
  #70
Old 05-16-2013, 09:34 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
How important is angle/rake for the motor? I have read about an offset to the passengers side, which I would like to do (probably only an inch). I can angle the back end as needed easily, but do not want to set myself up for failure aiming for close to level and square if it needs to be an exact science. This is my first swap, but I would rather not learn the hard way.
Don't know if you have this settled or not, but for those reading along: with a carbed engine the engine/trans should tip down at the back about 3 degrees. If you need a reference the intake manifold carb flange should be level when the chassis is sitting at ride height. (The intake manifold is wedge shaped). The engine can be offset in the frame to one side or the other (usually to the pass side for steering box clearance, but some engines are wide at the starter.) but the front to rear centerline needs to be parallel to the frame centerline. DO NOT angle the engine front to back between the frame rails! The tranny output and the rear axle pinion does not need to ( or should not) line up.
Unless those lines in the engine bearing journal are just oil streaks, you need to have that crank turned. Any journal wear you can see or feel with a fingernail is too much, the bearing journal needs to have a polished smooth surface. Those bearings were just about to fail when you can see the copper. While it is apart have the block boiled out in case the wear is due to a plugged oil gallery.
  #71
Old 05-19-2013, 02:04 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Andrew, It was cool to hang out with you at Truckfest! I will keep up with your progress! Glad you made it!
  #72
Old 05-19-2013, 02:23 PM
ALBUQ F-1's Avatar
postin' fool
While you may not need to cut the crank undersize, the journals HAVE to be polished or the new bearings won't bed in. Those don't look bad, looks like the PO may not have been rigorous about oil changes, or it was assembled dirty. Those scratches in the bearing babbit aren't serious.
By all means have it vatted and the oil passages brushed out thoroughly. New oil pump too. Being 60 over already does limit you, I'm surprised an '80's engine can go that far without overheating. Is there much of a ridge?
  #73
Old 05-21-2013, 10:44 PM
What do you mean by ridge?
I called the local machine shop... not too bad to get it polished... I do need to get a second look at the block... I am also evaluating fast-tracking by getting a motor I know works rather than heading down the slippery slope of the machine shop.... Only time will tell, I ordered a set of pullers to get the harmonic balancer off... gotta make room to keep the parts organized then pulling the crank with any luck. It seems like if I can find a working motor and transmission, I might give that a shot, as who knows if the AOD I purchased is going to work. Second Guessing....
  #74
Old 05-21-2013, 11:10 PM
ALBUQ F-1's Avatar
postin' fool
The crank really needs to be miked to tell whether it needs cutting or can get by with a polish. If it was run with loose clearances, the rods may need to be reconditioned.
You might just be trading a known engine (good or bad) for a pig in a poke, if you buy another engine. What year is the AOD? If it's pre-'90, it is considerably weaker than newer ones, unless it's been upgraded already.
  #75
Old 05-22-2013, 12:31 AM
Andrew I believe Ross is referring to a ridge at the top of the cylinders..aka ring ridge...wear in the cylinders.
78 F-150 Build F5 DEEG 1973 - 1979 F-100 & Larger F-Series Trucks 144 Yesterday 09:19 PM
BIGS 78 supercab build BIGS003 1973 - 1979 F-100 & Larger F-Series Trucks 66 08-06-2016 01:07 PM
Build Progress (So Proud) snook715 1948 - 1956 F1, F100 & Larger F-Series Trucks 413 11-02-2015 06:36 PM
F350 OBS BBslider001 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 11 07-20-2015 03:29 PM
Ford F1 Parts Northern Kentucky 52 Ford F1 Ford Truck Parts for Sale 11 04-22-2015 07:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
