My 52 Ford F1 Project - NKY - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-08-2012, 12:26 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I found the flywheel cover for the 215.
  #32
Old 09-11-2012, 10:12 PM
52 Ford F1 52 Ford F1 is offline
52 Ford F1 is starting off with a positive reputation.
Got some motor work done in the pics for this post.
Not posting again until after truck stock, lots to do before heading out for the weekend.
Still more work to go on the motor obviously, gotta make sure it all checks out before deciding to throw it in.
  #33
Old 09-19-2012, 09:28 PM
Learned alot at truckstock and met some great people... I think I might be alright with the stock steering after driving a few trucks. I still would like to do breaks, but until the motor swap the stock ones will work just fine.
The stock suspension is not horrible, but it would be nice to get the drop of an IFS.... I want to keep and lower the stock suspension but by the time you add up drop and forward springs, dropped axle, and the other misc front end items you are about up to an IFS. So needless to say I am torn... Hoping for a sign in the form of a good deal on one or the other...
Anyways, it was great to see a bunch of finished trucks and talk about everyone's build. Some pictures below, plenty more if you search the truckstock thread:
There was a lot of great trucks, but this was most similar to my plans with my own.
Back to the build.
Worked on cleaning up the bed. Had to replace both rear stakes and the rear sill. I used a drill on the spot welds and then the air hammer to separate the rest.
I bought a new rear valance that was supposed to be primed and ready to install from a company... It came unprimed and un-assembled... after 4 calls I got a $25 rebate, guess I can not complain too much.
Decided to weld the bed together solid instead of spot welds
At the end of the day I was thrilled with only 1/8 inch off square... I bet that was within Fords tolerance.... and with wood in it I could make it square. (Not to mention by the time I was done putting it together... It could have been 2 inches off and I would have called it a night)
  #34
Old 09-19-2012, 10:47 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Nice work! It is great to get results like that.
  #35
Old 09-22-2012, 11:04 AM
Lots of little jobs lately... most of the pictures are boring...
Finished burning in the bed, and had to fab a small panel (before welds cleaned).
Very time consuming to fix the bottom of the doors... May just cover the other side with sealer, than cover it with interior panels... I was expecting some issues, but the paint sure did cover a lot of holes!
Heading out to get some work now... Just a reminder, there is an open invitation for anyone whom wants to give me a hand in the Northern Kentucky/Southwest Ohio area - Free Beer and Food!
The weather is cooling too fast... not likely to get painted this year unless I can find a booth to rent... May be the best way to go anyways... Afraid to use heat lamps or heat guns...
  #36
Old 09-26-2012, 08:21 PM
Body Work Sucks
The worst part of body work is that even though I have put a lot of time into it... it still looks awful until painted.....
It also is not that interesting to look at... Tons of pictures of the same thing over and over just on a different panel....
Here goes some anyways if anyone is still following...
The tailgate was really rough as you would probably expect... Had some dings on both sides in addition to the rails... I did not aim for perfect with it... More so presentable. Eventually it would be better to replace then waste hours and hours trying to fix...
Had to do some filler work on the doors from the shaving of the door handles.
Hoods about done too... just need to get pictures up. Going to have to use some filler on the inner bed sides which is definitely less than ideal, but I can live with it for awhile. That pretty much leaves the cab, which is going to take a long time with the damage I did to the roof replacing the rear suspension.
Heading to Florida for at least a week, so I will not be making progress or posting for a while.
  #37
Old 09-26-2012, 09:01 PM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Great progress!! Keep posting the "boring" pictures as well. They're just as educational as the others. Glad you enjoyed yourself here at Truckstock too. Nice pics.
  #38
Old 10-01-2012, 02:26 PM
John.lee John.lee is offline
John.lee is starting off with a positive reputation.
Great thread. Keep the pics coming. I am currently doing the same on my 48
  #39
Old 10-01-2012, 03:49 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Yer doing great. Signing on to see this come together.
  #40
Old 10-01-2012, 06:41 PM
9teen56f100's Avatar
9teen56f100 9teen56f100 is offline
9teen56f100 is gaining momentum as a positive member of FTE.
Andrew,
Its all looking good. Keep posting your progress.
brian...
  #41
Old 10-01-2012, 07:16 PM
homade's Avatar
homade homade is offline
homade has a very good reputation on FTE.homade has a very good reputation on FTE.homade has a very good reputation on FTE.
Keep working on it and before you know long it will all come together.
  #42
Old 10-01-2012, 07:30 PM
barnfind 51's Avatar
barnfind 51 barnfind 51 is offline
barnfind 51 is starting off with a positive reputation.
Quote:
Originally Posted by 51PanelMan View Post
The stock 215 OHV I6 motor sounds healthy. If I were you, I'd keep it and use it. They're neat little motors. Here's what I did with mine.
Very Nice!! You did a fantastic job on the detail,Iam sure this is a sweet running truck. The engine bay looks great!!! I am aways away from where you are at but you show what can be done. Ididnt want to hijack the Thread but I did have to make a comment about what can be done..
super fine job !! on the detail looks great!!
  #43
Old 10-10-2012, 10:04 PM
Well, the fiancee lost her enthusiasm on helping with the truck as you can probably tell...
Kept going on the hood work. Finally put the (hopefully) final coat with glazing... Several guide coats later, and it I am thinking any defects that may exist will be taken care of with the blocking after spraying primer.
Also started on one of the rear fenders and the sides of the beds... Still have plenty to go, but after sanding, hammer and dolly, and all the other work I was doing my hands were shot...
  #44
Old 10-10-2012, 11:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Andrew, you've been a busy guy! That front fender is unfortunately real typical. If you don't want to spring for 'glass fenders for now, consider welding a big patch connecting the upper and lower in one fell swoop - that's how most 'glass fenders come anyway, as one piece. You'd be surprised how easy that is compared to re-creating the joint in each piece.
  #45
Old 10-21-2012, 07:19 PM
Went to the swap meet with Homade today and scored some good deals on some autobody supplies. (sandpaper, tack cloths, mixing pads, etc...) Had a good time and now I have no excuses for not getting any work done... I guess that is not true... Put in an offer on a house which was accepted. Inspection went well and if everything works out I will be closed by November 30th.. FINALLY MY OWN GARAGE! It's harder to work when you have to drive to the garage you rent and have working hour restrictions...
I have got a little work done on the roof... Took forever to beat it close to even... now starting the process of bondo. Will have more pictures, but if you are interested in why you can get a very large tarp very cheap at harbor freight... it is because it will rust/bond to your metal, rather than keep it dry.
Got my fiancee a birthday gift... which resulted in lots of work for me...
I traded a 99 taurus with plenty of it's own issues for this mustang and they gave me $250 bucks. When I got it the thing was filthy and had a horrible exhaust leak... Engine light on, brakes acting strange...
Homade and his friend helped me get it cleaned up last week.
The pipe had rusted after the collector, before the flange. Much less noisy now that it is welded up.
Underneath was not too bad.
Here is the exterior (very green)
Used those headlight refresher kits
Anyways, changed the oil, added some diff fluid, polished and waxed it, cleaned the heck out of the interior and have some of the misc trim pieces on order from ebay because it is hard to find a stang not picked over in the junkyard.
To give you an idea of how bad the interior is.
78 F-150 Build F5 DEEG 1973 - 1979 F-100 & Larger F-Series Trucks 143 11-13-2016 10:11 PM
BIGS 78 supercab build BIGS003 1973 - 1979 F-100 & Larger F-Series Trucks 66 08-06-2016 01:07 PM
Build Progress (So Proud) snook715 1948 - 1956 F1, F100 & Larger F-Series Trucks 413 11-02-2015 06:36 PM
F350 OBS BBslider001 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 11 07-20-2015 03:29 PM
Ford F1 Parts Northern Kentucky 52 Ford F1 Ford Truck Parts for Sale 11 04-22-2015 07:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
