My 52 Ford F1 Project - NKY - Page 2 - Ford Truck Enthusiasts Forums
Old 08-28-2012, 10:31 PM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
You are moving right along, and you got some suckers to help you with the dirty work, congratulations.
You mentioned a full blown motor swap, what are you looking to put in it?
I would vote to keep the current engine though, I tend to like the smaller engines. Now a days the original engines add uniqueness.
I look forward to watching your progress.
Old 08-28-2012, 10:45 PM
HeavytruckFan's Avatar
HeavytruckFan HeavytruckFan is offline
HeavytruckFan is starting off with a positive reputation.
Not messing around are you?
Boy these trucks sure do consume alot of time, money and effort don't they! You appear to be making great progress, good job! By the way, if you don't mind my asking, how do you get your lady interested in helping? What is your secret?
Old 08-30-2012, 07:16 PM
52 Ford F1 52 Ford F1 is offline
52 Ford F1 is starting off with a positive reputation.
I bought this for the engine (good timing). It is a 351 Windsor bored out a bit, with a mild cam. I had a little bit of buyers remorse after buying it, only because I do not have the experience to get it mated up to a transmission and bolted in to go. (I bought it for $750)
^ Of course I bought the motor before a motor stand or cherry picker... that was after I backed up a truck and threw it out of there... (HEAVY)
Went and bought a cherry picker to get a better look...
Before I got it all cleaned up.
That was before I got her the ring... since she is too busy planning the wedding and how to spend my money on other things than my truck...
To leave off with a lil more... pics after front fenders removed.
Old 08-31-2012, 01:39 PM
KidShalene's Avatar
KidShalene KidShalene is offline
KidShalene is starting off with a positive reputation.
Quote:
It's the beginning of an irreversible trend, ask me how I know.
Nice work & progress so far, good luck
btw, good looking Doby there....
Old 08-31-2012, 06:23 PM
Here is a better image of the doberman
Back to Progress....
More stripping of the cab and coating with some rust reformer in the interim.
With the fenders away I got a chance to look at the brakes, and wheel bearings
Took a video of the engine running before removing the rest of the needed life system... Hope the link works.
Antenna hole
Traditional Purists look away...
Seam
Front bumper removed
Draining coolant to get the radiator torn down
Old 08-31-2012, 07:34 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
You actually turned the truck back to stock by welding the antenna hole. The trucks didn't come stock with any holes for the antenna.
That 215 sounds healthy. You should find a good home for it.
Old 09-01-2012, 01:48 PM
Darn weather.... Rain expected all weekend.
To give you a better idea how far I actually am now, I took a trip to the paint store this morning. They had a sale going on a "paint kit" so I fell for it and bought the supplies.
I went with DuPont Nason Finishes... Speak now or forever hold your peace, it will remain unopened until after truck stock.
Nason SelectPrime 421-17/19 2k Urethane Primer gallon
Nason 491-17 Etch Primer quart
Base coat blend is also Nason products, their hot rod black kit gallon
Misc Supplies - file, filters, mixer, undercoat, masking supplies, etc
$200
I have both Bondo and Fiberglass filler, will be using much less than the PO but much more than I would dream about... (all steel = wet dream, just not practical when you have only a hammer and dolly)
Back to the work I have done so far -
The bottom of the stock motor.... Is there supposed to be a cover over the flywheel? I fully admit old motors are not my deal, hopefully not too stupid of a question.
Radiator and battery off
^My cousin helped out with some of the welding work while I stripped the under-body... Would have much rather been welding than laying on my back breathing rust dust. Once the dust was loose I used rust reformer than under-body coating
Stock front lower valance was in rough shape to start with... Pictures on what I did to it will follow in a few more posts.
Under tank rusted out around hole...
After my cousin welded that up, I got him to help strip the interior while I finished up the cleaning of the frame and under-body. (That is sarcastic enthusiasm)
What did I do to get his help???
^ That is an entire garbage can full of empties... ^
Going back to the comment about the previous owner not doing to much unorthodox...
^That is a plastic garbage can, cut to fit as the glove box.. Actually worked pretty well and looked alright if you did not know better.
Anyways... with the rain I hope to get some work done this weekend, will not be posting during the week coming up, will be traveling.
Old 09-01-2012, 02:17 PM
52'F-3's Avatar
52'F-3 52'F-3 is offline
52'F-3 is gaining momentum as a positive member of FTE.
i like your build thread, looks good and your making lots of progress....
Old 09-01-2012, 10:44 PM
REDS52F1's Avatar
REDS52F1 REDS52F1 is offline
REDS52F1 is starting off with a positive reputation.
Nice Truck
I just picked up a 52 as well. I have a basic plan but not sure on a few things right now. I will watch your progress, good luck!
Old 09-01-2012, 11:11 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Quote:
Welcome to the forum!
You should post a pic & tell us about your plans.
Old 09-02-2012, 06:10 AM
Doraville's Avatar
Doraville Doraville is offline
Doraville is gaining momentum as a positive member of FTE.
Welcome to FTE! You've come to the right place. The people here are a wealth of information... there's no way that I could have finished my project without them.
Notice that I said "people" and not "guys"; there are some very knowledgeable ladies on here too!
Peace and good luck,
-DV
Old 09-02-2012, 08:53 AM
Harrier's Avatar
No questions is a stupid question. If you have never done it before, how else are you going to learn. That's what I tell myself about every day.
Yes there is a cover for it. Here is a picture from the parts manual.
Oh, if you don't have one, I highly recommend it:
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
  #28
Old 09-02-2012, 12:27 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
I see 2 cans of truck stuff and MANY cans of "go-juice".
  #29
Old 09-02-2012, 12:49 PM
Thanks for the help on the flywheel, posted a separate thread looking for a used or new one. I could find them for the v-8 but not for the 215.
Stripped the front of the frame and coated with under-body spray.
Kept focusing on the front end, changing out all of the shocks and cleaning up the suspension. I think it was overdue.
^ with both of the shocks replaced, and the frame cleaned up and the suspension appearing stout, the front end was done. I am leaving the drum brakes for now, going to worry about getting the new motor in before the brakes.
Got some rot on all 4 cab corners...
Not the prettiest repair, but it will work.
Patched in the holes for the old upper and lower hood moldings... I am only going to run the middle strip to show off the louvers.
Running boards are all stripped, not perfect, but solid. Lots of hammer work needed...
  #30
Old 09-07-2012, 07:40 PM
Now comes the hardest thing I had to do for the truck so far...
I knew I wanted to get a small drop on the rear, and I figured now was the time with the bed off. While I did this, why not rebuild the rear suspension, should be easy enough... Yea right.
Got the rear end all jacked up... Did not realize it then, but the roof of the truck was jacked up into a cross beam in the garage... Earning myself likely a few hours to straighten out....
Rear looked pretty simple, just remove the holding pin and grease fittings to slide out the bearing should fall out of the bushing...
Ok, that was not easy, maybe if I dropped the weight of the axle entirely... I clamped the spring tack tight and tried to isolate the weight and cut the U-bolts with a grinder (that is me - for once a helper who helped document the build instead of telling me I was wasting my time)
One side done... I found out the secret about drilling a hole in the front cross member to be able to punch out the bearing from this forum...
After getting the passenger done, I turned to the driver and as par for the course got out the hammer...
About 20 minutes later I was worn out and the bearing was not budging...
More spray lube to soak in over night.
Next day I gave it a bunch more wacks and got it to budge with the help of the torch... Finally got it out after about 30 minutes straight of trading off with my cousin... I do not consider us to be small or weak people...
Here is what was left after cleaning up that spring mount on the front drivers side with a wire brush....
Angle on each side welded in took care of the issue. (overkill I know)
Re-Built the springs, removing a few of the lower leafs (some had cracked already) and added sections to the top to retain the overall leaf size
Installed a new bolt to hold everything together in addition to the new U-Bolts.
Re doing the rear suspension took an entire weekend, expected it to take the better part of 1 day.... in the end, I used about every tool I could think of... Not pictured with the lube, hammers, pry bars, torch, etc. is the air hammer, blood, sweat, and tears... this was a Bitch!
Getting the rear tires back on, Did not take pics of the rear frame all cleaned up nor after I sprayed it with under-body coating.
Of course I did the job that started it all, replacing the rear shocks at the same time
I did not paint the leaf springs, probably should have, but then again not a show truck..
BIGS 78 supercab build BIGS003 1973 - 1979 F-100 & Larger F-Series Trucks 66 08-06-2016 01:07 PM
Ford F1 Parts Northern Kentucky 52 Ford F1 Ford Truck Parts for Sale 11 04-22-2015 07:04 PM
96 F-series orifice tube location Beatdown Z 1987 - 1996 F150 & Larger F-Series Trucks 3 08-07-2011 11:57 AM
Oil in my Upper intake Plenum - Normal or Bad? teamshadyinc 1987 - 1996 F150 & Larger F-Series Trucks 9 12-26-2010 03:03 PM
homemade smoker monsterbaby General NON-Automotive Conversation 13 02-03-2009 07:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
