My 52 Ford F1 Project - NKY
  #136
Old 06-25-2014, 07:58 PM
52 Ford F1's Avatar
52 Ford F1
52 Ford F1 is offline
The company name was Pico. (Amazon Special) The only complaint is they were supposed to come with the black silicone coating applied, instead of the lighter cover. All and all I am glad I saved the money over the other catalogs - as long as they help with some heat control.
  #137
Old 07-26-2014, 01:15 PM
52 Ford F1's Avatar
52 Ford F1
finally fired it up last night, starting in on wiring now... Will need to get driveshaft made and trans cooler and fan mounted to set the cam.
Major milestone for me, hoping to move full steam ahead now (finally).
  #138
Old 07-26-2014, 01:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Congrats on the fire-up!
What's the covering on the brake lines, Nomex?
  #139
Old 07-26-2014, 02:42 PM
homade's Avatar
homade
homade is offline
looking good man
  #140
Old 07-27-2014, 01:49 PM
AXracer's Avatar
AXracer
AXracer is offline
You may already planning on changing it, but just a reminder to shorten that upper radiator hose so it does not loop up higher than the fill cap to avoid problems with air pocket formation affecting the cooling.
  #141
Old 08-11-2014, 08:43 PM
52 Ford F1's Avatar
52 Ford F1
Got a little further.
Starting to rough in the exhaust now. Gas pedal and linkages need to go in before I order my driveshaft, but I am not too far from driving in theory.
  #142
Old 08-26-2014, 04:27 PM
52 Ford F1's Avatar
52 Ford F1
Will need to add carb spacer, install mechanical fan, finish up some linkage, and switch out to the permanent valve covers - but the engine bay is starting to resemble a finished product.
  #143
Old 10-07-2014, 07:11 PM
52 Ford F1's Avatar
52 Ford F1
Slowly but surely coming along... Got some more wiring untangled, installed carb spacer and mechanical fan, figured out I had a bad proportioning valve and swapped it out for a wilwood - but the fun of rebending flaring and chasing leaks when trying to bleed is commencing. Took a "brake" from the frustration and started throwing some odds and ends on.
  #144
Old 10-07-2014, 09:45 PM
dmack91's Avatar
dmack91
dmack91 is offline
Stick with it - you will get there soon.
When I did my brake system, the first time I tested it, every joint leaked - yes, every one. I went through and loosened/tightened every joint several times to seat them down better and eventually got everything sealed.
  #145
Old 10-19-2014, 10:53 PM
52 Ford F1's Avatar
52 Ford F1
Brakes are finally done and driveshaft is on order
Time to start putting parts on for final mockup
  #146
Old 10-19-2014, 10:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Hopefully you'll get to drive it before the snow starts fallin'!
  #147
Old 10-20-2014, 12:45 AM
old_dan's Avatar
old_dan
old_dan is offline
I hope you get some primer on your bare metal before the Michigan winter arrives in full force!!
That is looking really good!!
  #148
Old 10-20-2014, 02:11 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
I for one see that suicide **** on your steering wheel
as an accident or injury waiting to happen. They work
very well on a fork lift truck as they where designed to.
Not so much on anything else. Sorry but ya got a great
truck other than that.
  #149
Old 10-28-2014, 05:47 PM
52 Ford F1's Avatar
52 Ford F1
  #150
Old 12-08-2014, 04:12 PM
52 Ford F1's Avatar
52 Ford F1
Temporary in theory, went with a sheet of architectural grade plywood and some leftover deck stain.
Battery is in the Hamm's cooler, got the tail lights mounted still trying to sort out all the wiring with the aftermarket wiring kit... found out a turn signal switch was needed for the brake lights to work, wired the back half of that up and still not working yet...
I checked the brake lights and they work when placed positive to ground, so I will have to get the circuit tester out and find a way to rig the brake pedal down... I am guessing it is my headlight switch, I am only getting 1 positive out besides the feed, and only with headlights on..
Quick Reply: My 52 Ford F1 Project - NKY
