Torque Specifications - Ford Truck Enthusiasts Forums
Old 08-23-2012, 06:47 PM
Glu Glu is offline
Glu is starting off with a positive reputation.
I am looking for the torque specification on the intake manifold bolts on a 1991 7.3 litre IDI diesel engine.
Old 08-23-2012, 08:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
Originally Posted by 87crewdually View Post
TORQUE SPECIFICATIONS TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
Camshaft Gear Allen Screw 15 (20)
Connecting Rod Nut Step 1 38 (51) Step 2 51 (69)
Cylinder Head Bolt (*1) Step 1 65 (88) Step 2 90 (122)
Step 3 100 (135) Step 4 100 (135)
Exhaust Manifold Bolt(*2) 35 (47)
Fan Clutch-to-Water Pump Nut 45 (61)
Flywheel-to-Crankshaft(*3) 47 (64)
Glow Plug 12 (16)
Injector Nozzle 35 (47)
Injection Pump Gear Bolt 25 (34)
Injection Pump Gear Cover Bolt(*3) 14 (19)
Intake Manifold Bolt(*4) 24 (33)
Main Bearing Cap Bolt Step 1 75 (101) Step 2 95 (129)
Oil Cooler-to-Cylinder Block Bolt Front Header 24 (33)
Rear (Filter) Header 14 (19)
Oil Pump Pick-Up Tube Bracket-to-Main Bearing Cap Nut 14 (19)
Oil Pump Pick-Up Tube-to-Oil Pump Bolt 14 (19)
Rocker Arm Bolt 20 (27)
Vibration Damper Bolt 90 (122)
Water Outlet (Thermostat Housing) 20 (27)
Water Pump(*3) 14 (19)
INCH Lbs. (N.m)
Rocker Arm Cover Bolt 72 (8)
NOTES:
(*1)At steps 1 and 2, tighten bolts in numerical sequence beginning with bolt No. 1. At steps 3 and 4, tighten bolts in line sequence beginning with bolt No. 15. See Fig. 3 .
(*2)Tighten to specification in numerical sequence beginning with bolt No. 1, then tighten again to same specification in line sequence beginning with bolt No. 4. See Fig. 2 .
(*3)Coat threads with thread sealing compound.
(*4)Tighten to specification in numerical sequence beginning with bolt No. 1, then tighten again to same specification in line sequence beginning with bolt No. 9. See Fig. 1 .
This may help
24 ft lb also stated in haynes diesel tech book #10330 as well.
figured id compare for ya.
Torque Specifications Richard51 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-27-2013 11:24 PM
Horsepower vs Torque bluestuff 1999 to 2016 Super Duty 63 07-18-2008 11:12 PM
5.4L Oil Drain Plug Torque Spec? whalerron Modular V8 (4.6L, 5.4L) 5 09-01-2003 11:07 PM
56 torque specifications bhabben 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-01-2002 06:35 PM
1992 f150 omalley 1987 - 1996 F150 & Larger F-Series Trucks 4 03-28-2001 08:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
