FRONT END SHAKE
08-23-2012, 02:15 AM
on
FRONT END SHAKE
MY 89 F-150 HAS A VERY STRONG VIBRATION WHEN GOING 35MPH OR BETTER WHEN YOU HIT A DIP OR POT HOLE ANY REMEDY FOR THIS
NO BRAKE APPLIED
08-23-2012, 06:04 AM
Search "death wobble" Check for loose steering and suspesion parts.
08-23-2012, 09:51 AM
on
All tie rod ends are new gear box tight
08-23-2012, 09:59 AM
on
Could worn I-beam pivot bushings cause the "death wobble"
08-23-2012, 12:19 PM
Quote:
Originally Posted by
djrod52
absolutely
08-23-2012, 04:35 PM
on
Along with ball joints, wheel bearings, any of the radius arm bushings, or wheel and or tire balance or roundness.
Do not install a steering stabilizer to 'fix' the problem. It will only mask the issue.
Is your suspension stock?
08-23-2012, 05:19 PM
on
anthonym92
03-26-2015 01:35 PM
Ric Carter
02-27-2013 09:08 PM
kwandrsn
Tennessee Chapter
01-29-2008 05:32 PM
SoloTSi97
1983 - 2012 Ranger & B-Series
08-10-2005 08:45 AM
mudder trucker
04-18-2002 12:59 PM
