My Official Build Thread (Lots Of Pics Coming!)
Old 07-16-2013, 02:51 PM
keiths78f150's Avatar
keiths78f150
keiths78f150 is offline
Ha thanks, but watching your thread makes me wish I did SO many things different.
  #212
Old 07-16-2013, 04:05 PM
jtindale's Avatar
jtindale
jtindale is offline
You and me both! I think that's why these projects never seem to end.
  #213
Old 07-16-2013, 11:01 PM
keiths78f150
Couple pics of what is going on with my truck.
351m Coming out
460 Being Built!
PARTS PARTS PARTS...Always a good day when the UPS man shows up
In the mean time, I am just dealing with small things that need done for when the motor gets done.
  #214
Old 07-16-2013, 11:08 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,287 Likes on 2,443 Posts
Kieth if you needed a black glove box door I had one.....ya gotta be real specific when it comes to parts requests.
If you and I would of know about your l&L header issue you could of gotten that new set of fenderwell exits off me I had and then shipped yours to me when they came in....oops
Oh well more time to work on other things.
  #215
Old 07-16-2013, 11:09 PM
keiths78f150
I did not want fenderwell exits...and as far as black glove box door, I decided I wanted black...like 8 hours ago haha
  #216
Old 07-16-2013, 11:16 PM
77&79F250's Avatar
77&79F250
No fenderwell exit oOOHHHH boy hope that decision work out for you. I had a inside the frame headers set ONCE and only ONCE, NEVER AGAIN.
PITA running the rest of the exhaust, all in and around your crossmember, heat and clearance issues with the starter, front d/s clearance issues, all around clearance issues.....ect.
Good luck with that.
Ok so is the complete interior going from red to black?
Remember those red/white door panels?
  #217
Old 07-16-2013, 11:33 PM
keiths78f150
Yep, no more red for me. Black/gray.
  #218
Old 07-16-2013, 11:36 PM
keiths78f150
If the chassis exit cause too much issue, I will switch. Not going to chop up fenderwells and rub my tires onto my headers unless I HAVE to.
  #219
Old 07-16-2013, 11:40 PM
77&79F250's Avatar
77&79F250
I had to only trim (no chopping involved) a few inches off the bottom of the inner fender to clear the set on ol red, and I have had no tire rub issues.
Of course ol red if a F250 with 6" of lift.
  #220
Old 07-16-2013, 11:49 PM
keiths78f150
Yea, stock with 33x12.5 will rub for sure...ill take my chances with the chassis and pray for the best. Im going to attempt to fab up some sort of heat shield to keep the heat off the starter. My girlfriends dad made one for his z28 he had back in the 60's and said it worked like a charm.
  #221
Old 07-16-2013, 11:52 PM
77&79F250's Avatar
77&79F250
Something like what the factory used between the muffler and the fuel tank on some newer vehicles??
  #222
Old 07-16-2013, 11:54 PM
keiths78f150
Yea, some sort of metal plate to disperse the heat a bit. He is the fabricator, I am the check book and willing guinea pig...haha
  #223
Old 07-24-2013, 11:37 PM
keiths78f150
Quick update, apparently my camshaft bearing bore was too small and while putting the cam in, screwed them up. After tearing it back down to the block, machine shop noticed the bore was messed up from the factory. He has seen this a couple of times when trying to add a big cam into it apparently, idk.
BUT, cam is in now and should have the motor ready by the weekend. Still waiting on headers, which wont be shipped till around the first. Stupid L&L.
  #224
Old 07-25-2013, 02:27 PM
fordcrzymike's Avatar
fordcrzymike
fordcrzymike is offline
You better post a video of that running 460 for us all to hear. Otherwise I'll be pissed...
  #225
Old 07-25-2013, 03:52 PM
keiths78f150
Mike we can meet up and you can hear it in person, but I will definitely have a video.
Quick Reply: My Official Build Thread (Lots Of Pics Coming!)
