Trying to diagnose a problem -- bad wheel bearings or rear clutch pack? - Ford Truck Enthusiasts Forums
Old 08-23-2012, 05:04 PM
dave247 dave247 is offline
dave247 is starting off with a positive reputation.
Unhappy Trying to diagnose a problem -- bad wheel bearings or rear clutch pack?
Hey guys. First post. I just got a 2004 Ford F150 Titan 5.4V8 with a little over 150k miles and I am trying to figure what the problem is with this noise I am hearing. It was from my dad who passed away, and he took pretty good care of it. Anyway I am running into a few small issues here and there and need some input.
When I am driving and come to a stop, then make a turn, I hear and feel a slightly quiet rumble noise from the rear axle that sounds like grinding or slipping. It only lasts for about one second, or for as long as I am turning. It doesn't sound horrible, but I know something is probably not right.
My brother, who had the truck for a little while, informed me that it was the rear clutch pack going bad. However, he is not a mechanic and I am hoping he is wrong. A mechanic friend of mine said that the lug nuts could be loose or it could also be the wheel bearings going bad. So we jacked up one of the rear ends and I pushed and pulled my wheel and felt just a little bit of play. I then tightened my lug nuts and there was no play. However the truck still makes the noise when turning.
Is there any way I can be sure which of the two problems it is (bearing vs clutch pack)?
Other notes:
- My ABS light flashes when I first start driving my truck and then remains on. I read in another thread that this can indicate the clutch pack problem.
- This truck recently had a front wheel bearing replaced... I assume they would have checked all the bearings though..
- A few days ago, I was driving and I heard something like metal slipping out and then I heard what sounded to be a piece of metal landing on the pavement and bouncing away... I thought "oh no..." Could that have been a wheel bearing? Hopefully it's just something I hit on the road but I doubt it.
Any help or input is very appreciated!
EDIT:What the hell is the difference between the rear clutch pack and rear wheel bearings? Aren't they in the same spot? Same thing? Similar things?..
Old 08-24-2012, 08:12 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
First off, does your truck have a limited slip differential? The axle code on the driver's door sticker would reveal this. If it's a Letter and a Number, then it's LSD. If you're only hearing the noise while turning, then the clutch pack in the diff is likely the culprit.
Tightening the lugs is always a good thing, but this is likely not the problem.
Other notes:
A bad wheel bearing (located in the wheel hub) just behind and inside where the brake rotors are, will "humm" at any speed while you're cruising. Usually as speed increases so will the humm.
The clutch pack is the limited slip package that is located within the rear pumpkin (aka, differential) in the center of the rear axle.
I hope this helps.
It sounds like a bad clutch pack for sure. Adding some friction modifier can help if the pack isn't too far gone. If you have to replace, then the mechanical LSD from Eaton is not a bad replacement.
Old 08-24-2012, 08:54 AM
It looks like it is an LSD. The Axle says "H9".
I did some more research and I also looked under my truck some more and noticed that the pumpkin looks like it's leaking fluid because the bottom right exterior has that wet look. It's not outright dripping, but it's clearly leaking. Also, my right axle seal seems to be leaking at the wheel because it has a wet area around it too.
I was thinking of following this guide here but I don't know if that will be a solution if the clutch pack is bad. Should I open up the pumpkin and see if the gears appear to be warn down or what?
Old 08-26-2012, 06:38 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
Sounds like you need to replace the right axle seal anyway. So you could change the diff. fluid and add the friction modifier. This might help on the clutch pack problem.
Old 08-28-2012, 09:48 PM
goracer's Avatar
goracer goracer is offline
goracer is starting off with a positive reputation.
I had A bad rear axle seal at about 60k and replaced both sides. Some people say replace the bearings since you have it apart but I was on a bidget and did not. No issues since and i'm at 124k miles. Synthetic gear fluid will not need a modifier addative.
2005 2.3l Manual transmission; squeaking at low speeds mmxchamp Ranger & B-Series 7 08-25-2014 02:45 PM
bad differential pinion bearing? 2bitsamile 1999 to 2016 Super Duty 6 07-23-2014 08:39 AM
intermittent wheel bearing noise. could it be something else? 96f15013ddie 1987 - 1996 F150 & Larger F-Series Trucks 3 10-10-2013 11:04 AM
2004 4x4 Expedition Road noise from axel? Cornell1 Expedition & Navigator 5 07-01-2013 08:55 PM
99 Expedition Rear Wheel Clicking Noise hgufrin Expedition & Navigator 4 07-03-2011 01:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
