56 ford f100
56 ford f100
yes,it's registered,has got number plates in the Uk.wasn't easy.sadly still has lots to do on it.can't upload photos
Probably will be a stupid question,but I would like to know it.
Ford 302 engine(serpentine belt),edelbrock 2121 intake manifold,edelbrock 1405 600 man choke carb on it.when the engine its cold runs fine,when its warm,runs like a bag of ****,and if I dont rev it engine stop,somebody suggested its sound like overflowing,need to set carb and ignition.is it matters which way I put the carb on?from the radiator,I've got the 2 adjustable screw on the cab side,friend told me need to turn the carb over,so screws on the radiator side.any ideas?sorry for the silly question.thanks guys,Tushy
I have no idea about your carb positioning, but here's one way to post pics...
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Hope that helps.
Tushy,
You carb is mounted backwards, the idle mixture screws are on the primary side of the carb and need to be at the front of the engine. We can figure out your issues once you turn the carb around. You might have a vacuum leak from the carb being backwards that is masked when cold from the choke being closed and making it run rich. Once warm, choke opens leaning out carb + vacuum leak= super lean. Runs like crap, dies, no power. Sound like your problem, I bet it does.
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
http://s1066.photobucket.com/pixlrEd...3D6a253274.jpg
http://s1066.photobucket.com/pixlrEd...3Dcb81a3de.jpg
http://s1066.photobucket.com/pixlrEd...3D37641882.jpg
http://s1066.photobucket.com/pixlrEd...3Db9023f45.jpg
http://s1066.photobucket.com/pixlrEd...3D349b4ae6.jpg
http://s1066.photobucket.com/pixlrEd...3D2187f240.jpg
thanks for the advice how to upload some photos.I know lot of work has more on her,but I hope ,one day will be ready
on
hi,
Tushy,
dcannon2663
17
12-03-2012 11:23 AM
aic
11-24-2011 09:17 PM
