1997 F150 5.4 2wd cruise control wiring
I know that I am continuing a very tired thread, but I need some help with cruise control wiring. The PO never had the recall mod done. Instead, he cut & re-wired under the steering column. So, I have the cruise control connectors (from the steering wheel switch) just dangling. I need a comprehensive wiring diagram. Neither the Haynes nor Chilton show much about the wiring to the actual switch. If I could find a diagram showing wire colors, I think I can undo the PO's remedy. Does anybody know where I can find a detailed wiring diagram for the cruise control system?
And, I do intend to replace the defective switch at the master cylinder before I get the cruise working.
Any help is appreciated,
Doulie
Doulie
MUSKRATT2
09-03-2011 09:49 AM
