Modular V10 (6.8l)
PCV Location?
Old 08-23-2012, 09:25 AM
pappy19's Avatar
pappy19
pappy19 is offline
PCV Location?
I am sure this has been covered before but my search didn't find it. At 110k on my 2008, I am sure my PCV needs to be replaced but I don't have a clue as to where it is located. Anyone changed theirs and can give an old dude some help finding it and any assistance on replacement would be greatly appreciated.
Pap
Old 08-23-2012, 10:06 AM
BCHauler's Avatar
BCHauler
BCHauler is offline
Not sure if the 3v is the same as the 2v, but on mine it is located on the top of the passengers side valve cover about halfway back. There is a thick insulated hose coming off of it. It just pulls out of the valve cover.
Old 08-23-2012, 11:27 AM
dkf's Avatar
dkf
dkf is offline
It is on the valve covers. If memory serves me right in order to replace the PCV valve on your 3V you have to buy the entire valve cover assembly because the PCV valve is not removable like on the 2V engines. If your oil consumption is low your probably better off leaving it alone.
Old 08-23-2012, 12:23 PM
pappy19's Avatar
pappy19
pappy19 is offline
OK, thanks. I remember now one of the Ford mechanics saying that it is tied to the inside of the valve cover and was a PITA to replace. So a sign the PVC is going bad is a sudden increase in oil consumption? Is that the only clue? Thanks-
Pap
Old 08-23-2012, 05:38 PM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
Usually yes a PCV valve is thefirst place to start. And you also have to buy the whole valve cover
Old 08-24-2012, 12:10 PM
mudfuel06's Avatar
mudfuel06
mudfuel06 is offline
Pappy, how much oil is your's using? I'm going through about a quart every oil change or 4000 miles.
Old 08-25-2012, 11:09 AM
jh818's Avatar
jh818
jh818 is offline
OMG! You need to replace the whole valve cover? Why did Ford design it that way? PCV valve should be easily replaced. It's like saying you need to replace your axle to change the brake rotors.
Old 08-25-2012, 03:11 PM
dkf's Avatar
dkf
dkf is offline
Probably cheaper for Ford that way, who knows. The trucks get more and more disposable and serviceable every year. All Ford is really concerned about it getting the truck past the warrenty period without costing them money, then it is your problem.
Expect it to get worse as the years go on, the vehicles get more complicated. Material cost increases, labor cost increases and the amount of time between complete redesigns is shortened.
I sure would not be concerned with that amount of consumption. I check oil level at least every week sometimes more depending on how much I drive.
sls1
02-04-2019 10:52 PM
cjben
04-02-2010 10:00 PM
jlabrecquevt
1983 - 2012 Ranger & B-Series
12-03-2008 08:31 PM
Jrock909
12-31-2006 09:54 AM
Will_01_GT
1978 - 1996 Big Bronco
03-29-2004 06:52 AM
Quick Reply: PCV Location?
