rear brake bleeding question
Old 08-23-2012, 06:00 AM
dfoxengr's Avatar
dfoxengr
dfoxengr is offline
when you all bleed the brakes are you doing something special with the left rear?
the bleeder screw is on the bottom which is why I ask. I did a quick bleed last night and couldnt get a firm pedal. Today I was going to invert the left rear and gravity bleed it so the bleeder was at the top, then bleed like normal.
I can report back on how that goes.
Old 08-23-2012, 06:30 AM
labman1014's Avatar
labman1014
labman1014 is offline
If the bleeder is on the bottom, u have the wrong caliper on there!! What yr Ex do u have? I recently did my rears and the computer at advance auto parts pulled up the wrong parts. I have an early build 2000 and the calipers r mounted to the left of the rotor on both sides. Which means it is actually the same caliper for each side. The computer pulled up different part numbers bc ford changed the calipers mid-year and r mounted toward the rear on both sides. Hope this helps!!
Old 08-23-2012, 07:29 AM
Sigskydiver's Avatar
Sigskydiver
Sigskydiver is offline
Do you happen to know when they switched that. Ive been messing with the Ex's rear end the last couple of days and both of my calipers are definitely on the inside. My truck is a 12/99 build
Old 08-23-2012, 08:32 AM
labman1014's Avatar
labman1014
Idk the yr they switched. Mine is an 11/99 build.
Old 08-23-2012, 08:48 AM
labman1014's Avatar
labman1014
What do u mean by say " on the inside"?
Old 08-23-2012, 08:49 AM
Sigskydiver
Hmm, well i'll be under it this afternoon and I'll have to look and make sure that stuff is on there correctly!!
Old 08-23-2012, 09:05 AM
Sigskydiver
NM, i read it the wrong way. I thought you were saying that the actual caliper itself on one wheel was on the outside. You just mean that they mount on the left of the rotor as you're looking at them. Doi moment.
Old 08-23-2012, 05:46 PM
dfoxengr's Avatar
dfoxengr
dfoxengr is offline
Ahh, yes. turns out the caliper was for an 02 vehicle.
Thanks Guys.
Old 08-23-2012, 06:14 PM
labman1014's Avatar
labman1014
Thanks Guys.
Yep, different mounts. The bleeder screw is always to be on top.
Old 08-24-2012, 06:01 AM
dfoxengr's Avatar
dfoxengr
dfoxengr is offline
that's what got me really confused. I knew it couldnt be right but didnt know why.
Old 08-24-2012, 06:21 PM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
oops, double post..
Old 08-24-2012, 06:24 PM
RACERX7775's Avatar
RACERX7775
Yup, it should look like this...
Name:  rear brakes.jpg
Old 08-25-2012, 08:47 AM
dfoxengr's Avatar
dfoxengr
dfoxengr is offline
Attachment 60020
No, that's the 01 or 02+ calipers. The 2000 caliper is ahead of the axle and the bleeder screw is in the other location.
Old 09-18-2012, 03:33 PM
RACERX7775's Avatar
RACERX7775
Does anyone have a pic of the brake setup for the 2000. I was thinking of regearing and buying an axle with 4.30 gears already because its so cheap. I didnt know that there was a different setup.
Old 09-18-2012, 05:06 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
On a 2000, one caliper is in the leading position and the other in the trailing position. They used the same caliper.
Quick Reply: rear brake bleeding question
