What did you do to the Bronco Today?
#3121
#3123
#3124
You do? I could probably make use of an adjustable valve so I can regulate the pressure between front and rear. Otherwise, my current property valve is in good condition. I don't think any of my extras would work if I even have them still. They were of of 2 F350s and an F100.
#3125
How do you hace your lines? Have any pictures of your set up?
#3126
Here is booster, and the PS lines.
I don't remember these photos but here is the Prop valve. Stock.
I guess at some point I pulled the bracket off to paint it. I don't member doing this though. It's a stock prop valve, and it's the old one I replaced with a junkyard one when I did the Booster conversion.
#3127
Rebuilt the front brakes, calipers, pads and hardware kit. Used it to pull a bunch of small trees out and then hauled a heavy load of firewood home with it. Still trying to get my Warn winch to work, it will wind the cable up but not out. 4 brand new solenoids. It is starting to annoy me.
#3130
#3131
Attachment 148551
Attachment 148553
Attachment 148552
Attachment 148551
Attachment 148553
Attachment 148552
#3132
We left the studs on place from the stock hardware and made new oles on the base plate of the booster. Due to GM having a much larger base plate on their boosters, we ended up drilling new holes. With a Ford unit you only have to expand the holes as they are just a little bit off. We did all this to ensure that this is just a bolt on mod and can be reversed at any time.
#3134
Ah, correction. We left the stock mounting holes. I was thinking of the truck I pulled the booster off of that had studs sticking out.
Attachment 149246
Attachment 149246
#3135
Well... bent isn't really what I'd call it.
I suppose it is at a bit of an angle. However, it is way longer than a Ford one. You can see it pass right by the brake pedal arm.
I had a member on here helping me(he did a lot of the work) and his idea was to make an "extension" of sorts. Works well enough but I feel like it's a weak link.
You can see where it bolts to the pedal arm, the other bolt toward the top of the photo is where the rod bolts to. Normally that bolts to the pedal arm like a Ford one would. This was just way too long so we had to improvise.
