What did you do to the Bronco Today?
#2806
#2807
depending on the miles on the chain. it will typically start running rougher before it jumps. Might be worth checking the deflection in it. The old chain sets were really only good for about 100K. I can't remember if that has the nylon toothed upper gear or not, I think it does though.
Based on my experience observing how lazy humans are, especially with preventative maintenance is probably the original.
#2808
#2809
After my Pinion fiasco, the drive line is in and working. I've been driving it regularly with a bit of highway driving and it seems to be holding fine. I had to return the drive shaft, I have to have a 1330 to 1310 conversion joint with a 1310 CV joint to mount to my transfer case... one more bump in the road. But, its all back together, and the heater works.
It has been running rough after the rug of war with nature. My carb is pretty beat up so I'm betting a rebuild/replacement will do wonders. I've said in the past that I want to keep the Carter for its history but it may be easier to just bite the bullet on a newer carb.
#2811
Finally got word on the transmission in my Bronco..............it's not worth messing with. Absolutely will not shift. Tried another solenoid pack and the "black box" and nothing. He says something has to broke inside.
Trying to decide what to go with. Ford reman.....Monster........or something else. Jasper maybe?????
#2812
Maybe a rebuild with upgrades? Shift kit, stronger guts...
For my 78, not much. Topped off the power steering fluid, I have a small leak. However I haven't dealt with it. Also, I had purchased a Marti Report a while back, it tells me all there is to know about my Bronco when it rolled off the assembly line. Now that I have an official paint code and name, I just ordered a 1/2 oz touch up bottle to see what it looks like. How close the current paint is. Eventually I may order a few spray cans for various custom parts
#2813
on
Bolted up the hitch receiver finally. it was just hanging there by two bolts before and would bend if you pulled on it. Got it secured and had some sunlight left so i went in the backyard and yanked a 1x3x3 hunk of solid concrete out of a ditch. Pleased with the hitch and how the Bronc had no problem holding traction in the process.
#2814
Picked up a brand new set of Headman headers complete with collectors, gaskets, and bolts, a used but perfect Edelbrock Performer 400, and a set of 351C 4V closed chamber heads.... All for $200.
One of the heads is rusted pretty good on half of it, but I'm pretty sure it's just surface rust. I have it soaked in PB Blaster right now. For the price I was willing to take a chance.
#2816
Found an annoying new rattle ... the drivers taillight assembly rattles with the radio cranked up. Thought it was just the outer cover but it's the assembly or something inside rattling around. Too dark to fiddle with it and work followed by a "your presence will be missed by the owner" last minute invitation to the company holiday party that I tried to get out of last week will prevent me from looking at it tomorrow like I want to
#2817
#2819
While I was planning out a motor rebuild, I found a place that has aluminum Aussie heads for the C block. I was excited and thought it would be a great idea for my 351 when it gets built. Then I read up on the low torque stuff and figured it wouldn't really help me much. I'm not looking for high rpm applications.
#2820
