1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 07-15-2014, 08:22 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
Can't wait to get my 79 back...ZF5/NP205 twin stick, Hydroboost braking system, saginaw pump, rear disc brakes, new 468....oh man....someone get me a towel.
  #2282
Old 07-15-2014, 09:32 PM
Deadsquiggles's Avatar
Deadsquiggles
Deadsquiggles is offline
Well, I dropped my bronco off at the mechanic yesterday to diagnose the stuttering or whatever you wanna call it. He called back today and the cats are clogged up and it's forcing the exhaust to try and travel backwards. So now I need new cats. I'm not sure how many are on these trucks, but whatever happens, I figure nows a good time to run dual exhaust.
  #2283
Old 07-16-2014, 01:38 AM
blackjack33's Avatar
blackjack33
blackjack33 is offline
Installed a new fuel pump and soft lines.
Didn't fix the problem...probably have to drop the tank.
  #2284
Old 07-17-2014, 09:01 AM
Deadsquiggles
I should be picking it up today. Two new cats, new y pipe, and a new Super 44 muffler getting put on.
  #2285
Old 07-22-2014, 10:46 PM
FourXFord2's Avatar
FourXFord2
FourXFord2 is offline
Finished running all of the accesory wiring. The lights on my Lund visor work for the first time since I owned it. Evicted a wasp nest from the visor,wife noticed it before I bumped it. had yo be 4 inchces from it at one point! Glad they were in lazy mode. Solenoid and actuator switch are wired as well as wiring for future front air locker. Fixed the tear in the headliner, sewed it with some thread for now. It should hold till I can get some new material.Run new spedo cable and installed the VSS on t-case. No plug for the 4X4 indicator on the 205. Oh well, I could rig some micro switches near the shift rails if I wanted to.
I can't wait to test this thing on a trail!
  #2286
Old 07-23-2014, 07:23 AM
FoxFord33's Avatar
FoxFord33
FoxFord33 is offline
congrats, man! Sounds like it's coming together.
  #2287
Old 08-01-2014, 09:57 PM
FourXFord2's Avatar
FourXFord2
Again the wiring stops me. I have 2 wires on the engine side to connect, no idea where they go. I ended up using a 5.8 harness pulled from a '90 F250 that was scrapped. I had saved all of the wiring from EEC forward.
any hoow I'm not sure where to run the orange wire and a red wire with a broken blue stripe. Orange wire appears to be grounded the engine block. and not conected directly to any other wires. I don't feel like pulling the harness apart to trace it out.
Another wire that is confusing me is a lt blue/yellow stripe on the '91 side of the harness. It can be seen here.
The other wires not traced out to source yet are white/pink, and a yellow/red. These 3 are on the '91 harness.
  #2288
Old 08-03-2014, 08:32 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
Well.....after a "Bronco" hiatus.......I figure it's time to get back on track. Decided that even though one ton drive train would be really cool.....getting the Bronco back on the road would be SO much cooler!!! I feel I've fallen prey to "Gee!!! That would be so cool in my truck syndrome!" I HATE when that happens!! (I think that's the kid in me!) How easily we are distracted!!
Anyway, I got under the Bronco and noticed that the rear seal didn't quite look right...so I replaced it again with a little bit higher quality one. I saw one of the freeze plugs on the back of one of the heads looked a little "funky", so I knocked it out and replaced it. I noticed that the engine has been out before, or at least apart. New oil pan, intake and head gaskets. I'm thinking maybe a short block???
Found a Dana 44 in a 79 Bronco. I've got dibs on anything I need out of it. Then a friend called me and told me he has a Dana 44 out of a 78 Bronco!! I guess I'll pick the better one. Calling a tranny shop tomorrow morning and gonna get my tranny to him.
  #2289
Old 08-03-2014, 11:27 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Sounds like good progress. More than ive done, I've been filling the cab with junk. Ive got 2 bumpers and 2 slider windows for the top. However, I don't even think I want them anymore. I've sorta, changed my decision.. I would rather have a soft top. I know a place that makes them.
  #2290
Old 08-05-2014, 07:45 PM
blackjack33
I didn't do a thing to my Bronco today. I'd planned a trip to the car wash today, needed the pressure washer...that didn't happen.
A local place? Send me the info if you'd be so kind.
  #2291
Old 08-05-2014, 09:54 PM
FourXFord2's Avatar
FourXFord2
I opened the hood, poked at a few wires with the DVM then banged my head on the grill gaurd repeatedly in frustration! Well not yet but it's getting to that point. I did find out that the red with blue dash is tied into the dk green/ yellow which is the SPOUT and IDM wire. I think that relates to the white/ pink wire on the '91 harness. I am going to write up the wiring on the '91 F150 at work, and try to find a '90 F250 with the 5.8 as well. Also searching for something better then the Haynes wireing pictures.
  #2292
Old 08-06-2014, 12:58 AM
GruesomeJeans
I wish, they are based out of New York. They make a tonneau cover type thing. I'll have to find the site but I can link to you. I wish they were here they need a 78 bronco to use as a "model" to make the tops for 78-9.
EDIT: here is the link http://www.aro2000.com/bronco_camper.htm
Its a "Fastback" style top. I kind of like the way it looks.
  #2293
Old 08-07-2014, 11:17 AM
bigzirb's Avatar
bigzirb
bigzirb is offline
I finally took the pile of stuff that had been stacked on the engine off and realized how much work I have left to do. It is a bit depressing. I'm off next week to install some flooring in the house so i hope to get done quickly so I can give the Bronco some love.
  #2294
Old 08-08-2014, 06:30 PM
Fordman96's Avatar
Fordman96
Fordman96 is offline
EDIT: here is the link bronco tonneau
I know what place you are talking about, but I'm drawing a blank on the name. I know for my 96' it's like $1,200 without the rollbar that holds the top.
I thought JBG sold them for the 78/9?
  #2295
Old 08-09-2014, 12:32 AM
blackjack33
Washed, clay bar'd, cleaner wax'd & hard wax'd the entire truck...polished the wheels x5.
Still not done, tomorrow I'll work on the inside, vac & detail & dress out the rubber.
Now, kickin' back, surfin' the interwebs, & enjoying a cold one.
Quick Reply: What did you do to the Bronco Today?
