What did you do to the Bronco Today?
#2282
Well, I dropped my bronco off at the mechanic yesterday to diagnose the stuttering or whatever you wanna call it. He called back today and the cats are clogged up and it's forcing the exhaust to try and travel backwards. So now I need new cats. I'm not sure how many are on these trucks, but whatever happens, I figure nows a good time to run dual exhaust.
#2285
Finished running all of the accesory wiring. The lights on my Lund visor work for the first time since I owned it. Evicted a wasp nest from the visor,wife noticed it before I bumped it. had yo be 4 inchces from it at one point! Glad they were in lazy mode. Solenoid and actuator switch are wired as well as wiring for future front air locker. Fixed the tear in the headliner, sewed it with some thread for now. It should hold till I can get some new material.Run new spedo cable and installed the VSS on t-case. No plug for the 4X4 indicator on the 205. Oh well, I could rig some micro switches near the shift rails if I wanted to.
I can't wait to test this thing on a trail!
#2287
Again the wiring stops me. I have 2 wires on the engine side to connect, no idea where they go. I ended up using a 5.8 harness pulled from a '90 F250 that was scrapped. I had saved all of the wiring from EEC forward.
any hoow I'm not sure where to run the orange wire and a red wire with a broken blue stripe. Orange wire appears to be grounded the engine block. and not conected directly to any other wires. I don't feel like pulling the harness apart to trace it out.
Another wire that is confusing me is a lt blue/yellow stripe on the '91 side of the harness. It can be seen here.
The other wires not traced out to source yet are white/pink, and a yellow/red. These 3 are on the '91 harness.
#2288
Well.....after a "Bronco" hiatus.......I figure it's time to get back on track. Decided that even though one ton drive train would be really cool.....getting the Bronco back on the road would be SO much cooler!!! I feel I've fallen prey to "Gee!!! That would be so cool in my truck syndrome!" I HATE when that happens!! (I think that's the kid in me!) How easily we are distracted!!
Anyway, I got under the Bronco and noticed that the rear seal didn't quite look right...so I replaced it again with a little bit higher quality one. I saw one of the freeze plugs on the back of one of the heads looked a little "funky", so I knocked it out and replaced it. I noticed that the engine has been out before, or at least apart. New oil pan, intake and head gaskets. I'm thinking maybe a short block???
Found a Dana 44 in a 79 Bronco. I've got dibs on anything I need out of it. Then a friend called me and told me he has a Dana 44 out of a 78 Bronco!! I guess I'll pick the better one. Calling a tranny shop tomorrow morning and gonna get my tranny to him.
#2289
#2290
#2291
I opened the hood, poked at a few wires with the DVM then banged my head on the grill gaurd repeatedly in frustration! Well not yet but it's getting to that point. I did find out that the red with blue dash is tied into the dk green/ yellow which is the SPOUT and IDM wire. I think that relates to the white/ pink wire on the '91 harness. I am going to write up the wiring on the '91 F150 at work, and try to find a '90 F250 with the 5.8 as well. Also searching for something better then the Haynes wireing pictures.
#2292
EDIT: here is the link http://www.aro2000.com/bronco_camper.htm
Its a "Fastback" style top. I kind of like the way it looks.
#2293
#2294
I wish, they are based out of New York. They make a tonneau cover type thing. I'll have to find the site but I can link to you. I wish they were here they need a 78 bronco to use as a "model" to make the tops for 78-9.
EDIT: here is the link bronco tonneau
I thought JBG sold them for the 78/9?
#2295
