What did you do to the Bronco Today?
#1367
#1369
#1371
"He said, as he wagged his tail"
Anyway... getting this one on topic: I found my front brakes pads are very worn already, and the spindle nuts came loose, hurting the SET 27 bearing in the proccess... which sucks... still, cleaned the bearing and repacked it with grease and seems to be working fine, but I'll replace it when I get to work on those brakes again soon. I wonder if 1 year is a short time for my brakes, as it seems that's what these lasted, Motorcraft pads btw...
#1372
Yikes 1 year does seem a bit short. Yet, I guess it depends on how often you drive and how hard you brake.
1 ton, if you have your license then you can't be half my age. That would make you 10 years old.. Last I checked in the US you can't have a license at 10. I happen to only be 20 years old and unfortunately can't even legally drink. Emphasis on "legally".
#1376
Dylan...squeal like a pig...boy.
Well my Bronco is still the same. Plan to put the 130 amp alternator on soon then the Mark VIII electric fan. When its hot around here..my temp goes to 190 yet I have a 165 thermostat in it. Hmm..
Thinking about getting a motorcycle and use it for a DD and park the Bronco and work on it and drive it on rainy days.
#1377
#1378
