1978 - 1996 Big Bronco
What did you do to the Bronco Today?
  #1351
Old 06-10-2013, 11:17 PM
ronjeremy6's Avatar
ronjeremy6
ronjeremy6 is offline
Thanks, Encho. I'll be reading your steering box rebuild write up in he near future.
A few other items that need attention:
Driver door won't lock (actuator?)
Windshield leaks due to a poor replacement install
Tailgate straps are snapped
Dash trim bezel is very loose. Looks like tabs have become brittle and cracked
The truck will be an ongoing father / son project. Looking forward to digging in!
  #1352
Old 06-11-2013, 01:17 AM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
That's a pretty small list compared to some of us. The bronco looks great, you did well getting it. I don't know how often you've ventured over here but we also have an on going picture thread that has a ton of cool pictures. Feel free to take a gander and post a few shots of this beauty.
  #1353
Old 06-11-2013, 01:44 AM
Zip's Avatar
Zip
Zip is offline
Nice looking Bronco. Moved mine into the yard and went camping. I wonder if it misses me yet.
  #1354
Old 06-11-2013, 06:44 AM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
Originally Posted by Encho
Man... that truck is just great... I wish mine looked like that.
X2 mine is beat up
  #1355
Old 06-11-2013, 07:15 PM
1_ton_bronco
Not a bad day for me lol.. Got ps pump pulley old pitman arm off the other pump and onto the new pump.. Cranked up checked fluid and drove er down z road straight.. Welded in new quarter panel too
  #1356
Old 06-11-2013, 09:34 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
I certainly hope you didn't put the old pitman arm back onto the new pump. I'd bet that was part of your steering issues before... If the pitman arm was attached to the pump... Just sayin'.
  #1357
Old 06-12-2013, 06:40 AM
1_ton_bronco
Good thinking I have a new pitman arm coming today.. Ill unbolt the old one and throw it out
  #1358
Old 06-12-2013, 08:07 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
You didn't get it: Even if you get a new Pitman arm you'll still have a problem since you're set in getting it attached TO THE PUMP.
  #1359
Old 06-12-2013, 11:31 AM
1_ton_bronco
I don't follow you there encho... Throw er up on jacks.. Unbolt drag link and drop pitman
  #1360
Old 06-12-2013, 12:16 PM
Encho's Avatar
Encho
Encho is offline
Man, you really killed this joke... The pitman arm is attached to the Steering Box (not the pump), which has absolutely no mechanical link to the pump, just the hoses for the steering fluid.
  #1361
Old 06-12-2013, 12:28 PM
1_ton_bronco
Lmao I'm breaking your ***** there encho
  #1362
Old 06-12-2013, 03:08 PM
GruesomeJeans
Back on topic. What I learned in boating school is....
But seriously, I finally did something with TGM today. I dragged her out of her comfy gravel parking spot and drove her up the freeway a bit. The vw developed a nice squeak and I think it's coming from the genereator so rather than chance getting stuck with a seized genny, I parked it and got the bronco out. after about a minute of cranking and pumping the gas she finally fired up sounding as good as ever. I warmed her up then left to go to a possible job interview.
So after standing around for about an hour and a half with about 10 other applicants we discovered that my online application cannot be opened by the managers. They can't see it at all even sooo they sent me home. Needless to say, I was quite upset so I did what any man wih a big noisy truck does. I drove like a mad man and yelled a bunch. On the list is driving well over the speed limit, swerving into a gravel area to get past a car and a semi that stopped on a 2 lane street, fishtailing and spinning my 35s in said gravel area, almost going as over tea kettle onto a ditch from the aforementioned fishtailing, then speeding off leaving an awesomly big dust cloud. I like to think of myself as a pretty skilled driver. I could have very easily lost control and flipped of I hadnt been able to get the ol beast back under my control. That with lots of loud music helped me lower my stress level by a lot.
Although I'd have to say, I have always wanted to hit that gravel area to pass someone but never dared try it due to all the big potholes along the edge of the road... This time though, I didn't care I just hammered it and the bronco handled it beautifly.
I guess when I've only had an hour and a half of sleep and something like that happens, I shouldnt drive.. I didn't get caught this time though and no one was hurt, the truck made it home despite what I put it through... All is well now.
  #1363
Old 06-12-2013, 06:07 PM
1_ton_bronco
Got wheel cylinder and center brake hose and z last brake line installed
  #1364
Old 06-13-2013, 10:48 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
Ordered coil spring insulators and hardware kits for the radius arm brackets from Bronco Graveyard. Pulled the coil spring retaining nuts (thank-you WD40 Rust Release Penetrant!!) Insulators were almost non-existent!! Installed new rotors and brake pads.
  #1365
Old 06-14-2013, 12:31 AM
GruesomeJeans
All I did was drive TGM up to get my sister from the 8th grade formal dance. Impressed her friends with a little engine revving and crazy redneck driving :P
Quick Reply: What did you do to the Bronco Today?
