What did you do to the Bronco Today? - Page 7 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
  #91
Old 10-12-2012, 01:40 PM
Southern Bronco's Avatar
Southern Bronco Southern Bronco is offline
Southern Bronco is gaining momentum as a positive member of FTE.Southern Bronco is gaining momentum as a positive member of FTE.
Just got done putting an old set of 33s on the 94, so I can go play alittle if I get the chance. Will post picts of her over the weekend
  #92
Old 10-12-2012, 01:44 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
Havent really done much, did some body work a few weeks ago, got most of the biggest section of rust taken care of. Still in search of tires on craigslist
  #93
Old 10-12-2012, 02:17 PM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
Torched all shackles .. going to install 4 new ones and finish leaf spring bushings
  #94
Old 10-12-2012, 09:40 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
Had to do a roadside reair on my way home tonight.
Down shifting for an intersection and tranny made it into neutral, but the shifter got jammed up. Had to pull the boot, shift lever and the top seal with the ball. Inserted a long puch into the rail and lined it back up into neutral, put it back together and was on my way again. I am thinking now would be a good time to "upgrade". I've got a ZF on it's way and might bolt it to a NP205 t-case. Need to find the driveline measurements so I can get started on driveshafts. Time for a beverage. or 2.
  #95
Old 10-12-2012, 09:49 PM
Yea thats what i wanted to do.. find a zf5 or m5od.. convert it and put a tcase in there
  #96
Old 10-14-2012, 07:10 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Well i drove TGM today and boy it was rough. The engine is missing a lot now and when you let off the throttle going down hill or from driving fast it pops and sputters. I need to look at the dizzy cap and pull a couple spark plugs to see what the issue is. I had been thinking that maybe the plugs were fouled since i haven't been driving much and when i do it doesn't really get warm.
  #97
Old 10-14-2012, 07:29 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Theres a complete pile to swap over from an auto to a manual in the classifieds.
  #98
Old 10-14-2012, 08:00 PM
Don't have the money since my 63 just got painted...
Finished rear shackles and burned out old leaf spring bushings..
I like the way it sits with 1.5 " lift coils in the front
Sits level.. should have been factory ride height.. not whre the front sits lower like a pickup
..here's the pic...
  #99
Old 10-14-2012, 08:22 PM
Edgethis's Avatar
Thats a great looking truck there.
  #100
Old 10-14-2012, 08:57 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Thats a great looking body on that 63!
I threw the front diff cover for the Bronco in my electrolytic solution to clean it up so I can paint it. I am going to put it back on to keep everything lubed until I can afford a gear swap.
  #101
Old 10-14-2012, 09:17 PM
Yup thanks for the compliments!!
I drive this thing around my building parking lot until my garage gets cleared out..
I get so many compliments.. Its a head turner
  #102
Old 10-14-2012, 10:14 PM
I sure looks like one.
Zirb what color is the cover going to be?
  #103
Old 10-15-2012, 01:16 PM
bigzirb's Avatar
I am planning on painting the diff covers and all of the exposed hub blue if I can find a blue to match my body color. I checked the cover and the solution is even peeling the crappy paint off so I decided to let it run a little longer so I have less to prep before I paint it.
  #104
Old 10-15-2012, 03:54 PM
I see. Blue would look pretty good. It's hard to imagine white diff covers haha.
  #105
Old 10-16-2012, 05:11 AM
bigzirb's Avatar
Quote:
Just check out the rear of my Excursion. White painted cover with the bolts painted black. I like to be different.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 02:38 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 02:19 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
No Regrets Bronco/ Cummins Bronco Build Oldironsfury 1978 - 1996 Big Bronco 1 09-07-2012 10:25 PM
2010 FTE Bronco Championship Round-8 Entry Thread. 76f350spercamprspeal Picture competitions 5 08-02-2010 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
