What did you do to the Bronco Today?
#811
After a pneumatic gun you always try them all with a proper lugnut wrench (the cross type) in order to check them all. I even do this at tire shops, and it paid out once when the stupid kid left all my tires loose, tightened them while on the jack, didn't finish after he lowered the truck.
#815
Anyways, I went to the gas station. I had less than a quarter of a tank left. Thinking I would reach the full mark around $70 or so would should prove me wrong. Came out that the tank was full at $47 (13.666 gallons). WTF? That meant that my tank was reading that less than a quarter of gas had 12-13 gallons of gas still in it! WTF?!? I kept pumping and the gas dispenser was clicking telling me my tank was full. My fuel needle read way of the Full mark like it did before.
It's a new fuel sending unit for my 25.5G tank. People did say they usually don't read correct. I guess when I run out of gas it will be way pass the Empty line.
Oh well. I'll probably will run to about half tank and fill it back up and check and see what my mileage is.
#816
Hrmm, weird. Maybe as a test siphon the fuel out into another container (my tank?? ) until there isn't hardly any left then run it out of gas completely to see where the needle sits. If it's past E then that's probably not a bad thing, if it's at E or above, that may be an issue. This way will also tell you your limits for the future.
EDIT: All I did was look at this sad hunk of metal... I peeked in the axle tube to see what it looked like but otherwise I did nothing.
#817
#818
I took off work today (and lost $) however I did the driver side rusty 1/4 panel.
After trim removal and some tapping..
The driver side looked like this early today.. I then shot some Rust Reformer into the hole.. Then used long hair fiberglass 'hair'..
With fiberglass, a skim of Bondo, & primer.
With non-matching paint.. waiting on the factory MS color code paint to come in from Amazon..
#819
So I came across this center console on sale, ive been thinking about getting one but I just cant spend the money on one. Im gonna put the link **HERE**, so i'm not trying to advertise any websites. If this is considered advertising someone let me know and ill delete this comment. Anyway I am quite tempted to buy one. Does anyone have one that can post pics?
#820
#821
#822
#825
Got er done today.. Pulled timing cover and water pump off.. Got one broken bolt out and left the other one.. Wasn't gonna bother if there's only 1 broken bolt still stuck.. Timing chain had very little slack.. I'm amazed 184k miles and its still good., but gotta start bolting everything back up tomorrow when I get a different gasket for the water pump to plate... Dropped the whole oil pan too lol.. Did a lot today and time for some food
