What did you do to the Bronco Today? - Page 55 - Ford Truck Enthusiasts Forums
  #811
Old 03-25-2013, 08:32 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
After a pneumatic gun you always try them all with a proper lugnut wrench (the cross type) in order to check them all. I even do this at tire shops, and it paid out once when the stupid kid left all my tires loose, tightened them while on the jack, didn't finish after he lowered the truck.
  #812
Old 03-25-2013, 09:17 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Ah. The shop I go to they impact them on then drop the truck and torque them with a torque wrench after.
  #813
Old 03-25-2013, 09:46 PM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
Dylan... I always use a impact to tighten them down on a jack.. Then crank em down with a breaker bar so I know that tire isn't going anywhere
  #814
Old 03-26-2013, 04:53 PM
Fordman96's Avatar
Fordman96 Fordman96 is online now
Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.
Put the Ronco up for sale today just to see what kinda offers I get until the end of the summer. Hope that it does/doesn't sell!
Also looked into some new deep dish rims.
  #815
Old 03-26-2013, 10:38 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
You're selling your Bronco?!? Why?!?
Anyways, I went to the gas station. I had less than a quarter of a tank left. Thinking I would reach the full mark around $70 or so would should prove me wrong. Came out that the tank was full at $47 (13.666 gallons). WTF? That meant that my tank was reading that less than a quarter of gas had 12-13 gallons of gas still in it! WTF?!? I kept pumping and the gas dispenser was clicking telling me my tank was full. My fuel needle read way of the Full mark like it did before.
It's a new fuel sending unit for my 25.5G tank. People did say they usually don't read correct. I guess when I run out of gas it will be way pass the Empty line.
Oh well. I'll probably will run to about half tank and fill it back up and check and see what my mileage is.
  #816
Old 03-26-2013, 11:13 PM
Hrmm, weird. Maybe as a test siphon the fuel out into another container (my tank?? ) until there isn't hardly any left then run it out of gas completely to see where the needle sits. If it's past E then that's probably not a bad thing, if it's at E or above, that may be an issue. This way will also tell you your limits for the future.
EDIT: All I did was look at this sad hunk of metal... I peeked in the axle tube to see what it looked like but otherwise I did nothing.
  #817
Old 03-27-2013, 06:56 AM
Fordman96's Avatar
Quote:
So that way I can buy the 79 that I want. A good friend of mine had one for 400 and it just needs a fuel pump to start running again. Oh and some seats + whatever else he has parted off it
  #818
Old 03-27-2013, 03:26 PM
ywhic's Avatar
ywhic ywhic is offline
ywhic is starting off with a positive reputation.
I took off work today (and lost $) however I did the driver side rusty 1/4 panel.
After trim removal and some tapping..
The driver side looked like this early today.. I then shot some Rust Reformer into the hole.. Then used long hair fiberglass 'hair'..
With fiberglass, a skim of Bondo, & primer.
With non-matching paint.. waiting on the factory MS color code paint to come in from Amazon..
  #819
Old 03-27-2013, 06:06 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
So I came across this center console on sale, ive been thinking about getting one but I just cant spend the money on one. Im gonna put the link **HERE**, so i'm not trying to advertise any websites. If this is considered advertising someone let me know and ill delete this comment. Anyway I am quite tempted to buy one. Does anyone have one that can post pics?
  #820
Old 03-27-2013, 06:16 PM
Encho's Avatar
Researched the heck out of the B&M Shift Kit install, so I guess I'll be doing that tomorrow, and find which year E4OD replace mine, any tips? I already know about the check ***** (it's actually the only thing that worries me).
  #821
Old 03-27-2013, 06:19 PM
Started timing cover... Got 90% of the way.. Can't get the damn cover off lol.. Sprayed some pb blaster and see if it'll come off in the morning... And someone broke 2 bolts inside the block.. Which ain't bad.. But grade 8 and replace em all
  #822
Old 03-27-2013, 07:35 PM
Got 1 step closer to driving the bronco. My boss was nice and gave me a backing plate off of a 9" he had. I just have to clean it a bit and it should be ready to go.
  #823
Old 03-27-2013, 07:49 PM
The old one is aight.
  #824
Old 03-27-2013, 08:08 PM
Yeah haha. Far from it.
  #825
Old 03-28-2013, 05:50 PM
Got er done today.. Pulled timing cover and water pump off.. Got one broken bolt out and left the other one.. Wasn't gonna bother if there's only 1 broken bolt still stuck.. Timing chain had very little slack.. I'm amazed 184k miles and its still good., but gotta start bolting everything back up tomorrow when I get a different gasket for the water pump to plate... Dropped the whole oil pan too lol.. Did a lot today and time for some food
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 01:38 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 12:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 01:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 02:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 06:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
