What did you do to the Bronco Today? - Page 54 - Ford Truck Enthusiasts Forums
  #796
Old 03-22-2013, 11:31 PM
Skip1970's Avatar
Skip1970 Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
i did nothing again. wheres the ashamed smilie.?
  #797
Old 03-22-2013, 11:46 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Quote:
Originally Posted by Encho View Post
You left the lugnuts loose, how can you be sure? check the stud holes in your rim, you'll see the studs filed them... I did that once with one front tire, luckily I only messed the rotor, the tire and the rim, and my insurance paid for the damages on the taxi my tire decided to visit. BTW, check that tire for deformations, if it has any then it's a goner, and if the rim holes are filed you'll need to have it replaced or repaired (I would use it for the spare as I did with my repaired rim).
P.S.: You're and idiot (me too), and I'm glad you didn't get hurt nor hurted someone else.
Haha I know it
Btw what did you mean by "filed lug holes"? Like out of round ones? Mine are pretty chewed up from the lugnuts cutting into them. I planned on asking my boss if he had any 15x8 steelies that he doesn't want. He said he had a 9" rear end that the inards are toast on and he said I can pick parts off it for mine if I need too, he also has a lot of rims to repair the plumbing trucks/vans. I could get 4 of those and keep one of my aluminum ones as a spare (as you suggest) but I still have an issue of finding a place for the spare. I kind of like those roof baskets that some jeeps have where they have a tire and fuel but I don't know how they look on a bronco. I don't have room inside for a 35 to hang around.
  #798
Old 03-23-2013, 07:10 AM
ywhic's Avatar
ywhic ywhic is offline
ywhic is starting off with a positive reputation.
I have an old school 4 way (gotta be 16-18 across) and use the creaking noise approach when putting on lugs.. when it creaks or groans just once I stop..
I need to get a 5 pack of lug nuts though.. I have some of the 'chrome ones' on my factory AL wheels that have like split thin covers.. and putting the lug wrench on all the way can't happen..
  #799
Old 03-23-2013, 04:26 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Picked up the crap in the console and the rear and classified it, I spent more than 5 hours doing so. Now it's almost empty. I also isolated the A/C hoses and dryer to make the system more efficient. Finally, installed some trim clips that were missing, sadly some didn't go all the way in.
  #800
Old 03-23-2013, 05:53 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Did rear brakes(shoes, hardware, wheel cylinders)
Found IDIOT who put the 4.56 gears and locker in did not properly torque things. Lost 2 of the ring gear bolts. When they got tossed around they beat up the VSS gear and punched a hole in the cover. Pinion bearing is also done as well.
Installed rear sway bar. I relocated the frame side of the end link to compensate for the lift block.
Changed the 5 speed and t-case fluid as well
  #801
Old 03-23-2013, 09:56 PM
Southern Bronco's Avatar
Southern Bronco Southern Bronco is offline
Southern Bronco is gaining momentum as a positive member of FTE.Southern Bronco is gaining momentum as a positive member of FTE.
Changed the oil and filter, replced the fuel filter,belt and tensioner on the 96. Getting it ready for road trip in a couple of weeks.
  #802
Old 03-24-2013, 12:25 AM
Encho's Avatar
Just an hour and a half ago I received the OD button and cap and installed them on the shifter lever, it's nice to have all that working properly. Keeping the old button surely would have hurt the new trans since at times it activated/deactivated randomly (thankfully it never did at highway speeds, and I took it out once it got worse).
  #803
Old 03-25-2013, 10:00 AM
Kasper78Bronco's Avatar
Kasper78Bronco Kasper78Bronco is offline
Kasper78Bronco is starting off with a positive reputation.
Replace PVS switch on manifold, tightended up collector bolts, installed a seal in the transmission linkage that I forgot on the rebuild, put a new c clip on the throttle linkage that kept falling of, checked torgue on the manifold, and installed a port on the carb. Then spent 5 hours attempting to get the vacuum lines, EGR, PVS, amplifier, cannisters, check valves all hooked up. What a fiasco that was...somewhere there's a vacuum leak. Wound up putting it back to before starting, and it runs worse; but sometimes idling on a new build will foul a plug since the rings aren't completly sealed...or so I've heard.
  #804
Old 03-25-2013, 10:16 AM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Bet you ****ted on yerself Dylan. Lol.
Glad yer ok.
Buy a cordless impact gun.
  #805
Old 03-25-2013, 10:17 AM
Quote:
Where r u goin?
Trucks Gone Wild will be in Hortense on the 16th. Im thinkin about going BuT idk.
  #806
Old 03-25-2013, 10:33 AM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
Dylan had to **** himself... Lol...
Started to undercoat the frame.. Did another shock.. And new hardware... All new vacuum lines with rubber hoses.. 5/32 or 4mm... Swapped tires from my 96 to my 93 since a 10.5 and Dana 50 swap is going to happen.. Get r done!!!
Timing cover next on the list
  #807
Old 03-25-2013, 10:49 AM
What are u coatin yer frame with?
  #808
Old 03-25-2013, 02:47 PM
Just stuff from lowes lol nothing special..
  #809
Old 03-25-2013, 03:45 PM
Quote:
Originally Posted by ManfredVonRichtofen View Post
Where r u goin?
Going to Ellijay the 1st weekend in April.
  #810
Old 03-25-2013, 07:59 PM
yeah it was scary. But an impact gun is the reason this all happened. The pneumatic one I have didn't tighten them as much as I thought.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 01:38 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 01:19 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 12:13 PM
1977 F150 Ranger AKA "Whitey" AKA "The Man" Restoration DieHardChief 1973 - 1979 F-100 & Larger F-Series Trucks 33 01-28-2014 12:23 PM
78 Bronco Build/Resurrect justin Wallace 1978 - 1996 Big Bronco 92 05-17-2012 10:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
