1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 03-15-2013, 11:34 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Originally Posted by ManfredVonRichtofen
The E4OD?
Sadly... Yes, I don't have the funds or time to get involved in a full swap right now, and I got a great deal, plus with the mods I already have and the B&M shift kit I just ordered* this transmission will have a long-happy life (knock on plywood).
B&M 10025 Shift Improver Shift Kit : Amazon.com : Automotive B&M 10025 Shift Improver Shift Kit : Amazon.com : Automotive
  #752
Old 03-16-2013, 08:39 AM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
C6 and gear vendor would be better BUT expensive.
  #753
Old 03-16-2013, 04:11 PM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
Yea c6 would be better but to ship it from the states... Probably an arm and a leg
  #754
Old 03-16-2013, 05:29 PM
Encho's Avatar
Encho
Encho is offline
I can source a C6, just not sure if a 4WD (probably yes), but near $3000 for a Gear Vendors unit is way out of my reach.
  #755
Old 03-16-2013, 05:37 PM
1_ton_bronco
Outrageous... 3k.. Could get a 5 speed trans for like half that
  #756
Old 03-16-2013, 05:43 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
1Ton, that's about how much a brand new C-6 is here in the states as well. I used to work for a dealership and they got trannys in from a company called Jasper, I had them grab me a quote and I think it was around 2-3k. Not with installation. I will see if I can find it in my thread from my rebuild.
Today I watched my truck get pelted by rain...
EDIT: I was incorrect, I found my posting and it was $1,345 WITH my small employee discount from my work. I had thought that was a good deal back then, sheesh.
  #757
Old 03-16-2013, 05:45 PM
1_ton_bronco
Yea weather sucks here.. But on eBay a rebuilt 5 speed is like 1200-1500
  #758
Old 03-16-2013, 07:09 PM
GruesomeJeans
Put gas in the truck... $73 got me from under 1/2 tank to a completely full tank. Hopefully that lasts.
Also I may have to diag my vacuum system, I can hear a whistling sound when the engine is running, similar to a leak. It doesn't seem to be running badly though so I can't imagine what it is. I also spent $70+ on some new work boots. they ar the Georgia Giant romeo slip on boots. They aren't cheap but if they can hold up in my line of work, I'll be happy. Next I need a tape measure and a few other odds and ends.
  #759
Old 03-16-2013, 07:42 PM
ManfredVonRichtofen
How long does a full tank last you?
U got the 33 gal or 25.5?
I got the 25.5.
Gas is from $3.52/Gal to $3.62/Gal here.
  #760
Old 03-16-2013, 07:51 PM
GruesomeJeans
33 gallon here That *might* last me this week if I am careful. I use about 1/4 tank making a round trip to and from work. That's... 34.4 miles. So I think that's around 8 gallons per day without extra driving to stores or w/e.
  #761
Old 03-17-2013, 11:16 AM
1_ton_bronco
Ha... I'd be lucky to get 150 miles or 200 miles on 32 gal tank.. On my f250
  #762
Old 03-17-2013, 11:21 AM
ManfredVonRichtofen
What engine?
  #763
Old 03-17-2013, 11:22 AM
1_ton_bronco
5.4 it's a workhorse but eats gas
  #764
Old 03-17-2013, 12:41 PM
ywhic's Avatar
ywhic
ywhic is offline
I used a drill based paint/rust removal wheel to clean off the caking of rust on the radius arm I just had the new bracket put on last week.. then hit it with some Rustoleum Rust Reformer.. also did the shock tower after scraping off the off undercoating that was falling off.. while not perfect it will/should last a little longer than just leaving the rust sitting their munching..
Still drying photo..
  #765
Old 03-17-2013, 07:08 PM
Encho's Avatar
Encho
Encho is offline
Left the truck at the shop to have the transmission swapped tomorrow. Let's hope all goes well and I have my truck ready either monday ir tuesday.
Quick Reply: What did you do to the Bronco Today?
