What did you do to the Bronco Today? - Page 2 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 08-26-2012, 07:23 PM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
HD BUMPER
old warn enforcer bumper i made some sides and put some tubing on it
still not done..
Old 08-26-2012, 07:39 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Finished up rebuilding my hubs. It was a pain but i got it done. I also drove down to AutoZone to buy my neighbor a new Spindle Nut Socket. I kinda jacked his up...
Old 08-26-2012, 08:02 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Put a new copper exhaust gasket on one side today.
Old 08-27-2012, 10:58 AM
Boss351Bronco88's Avatar
Boss351Bronco88 Boss351Bronco88 is offline
Boss351Bronco88 is gaining momentum as a positive member of FTE.Boss351Bronco88 is gaining momentum as a positive member of FTE.
Bought Timing Tape, and a MSD Digital 6AL box (one with the Rev Limiter) for the Bronco. Going to Order a 3in Electric Dump later on this week. And prepping tools and the garage for the motor install this upcoming weekend.
Old 08-27-2012, 05:23 PM
I tried and failed at replacing some fuses. I have the glass ones and the PO decided he was too cheap to buy some so he used tin foil. Of course this doesn't jive with me too well so i figured i would take a look and fix it. Turns out i don't have the correct fuse either... I did however pull the tin foil out for safety sake. once i get some more fuses that will work i can fix it. One was for the instrument cluster and the other i am not sure about. All it said was coast Lbs and it was i think 15 amp.
Old 08-27-2012, 10:19 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
I finished welding the firewall and painted it. I went back to working on my front hub rebuild. TGM is inspiring me. I dug out the bumper I am going to be using on the rear of my Bronco and started figuring out how to modify it to work.
Old 08-28-2012, 03:11 AM
Quote:
Glad to hear that something positive is happening from TGM
Old 08-28-2012, 03:36 AM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Thought about starting it, but was too lazy to
Get the keys. Maybe tomorrow.
Maybe not, two other trucks need oil changes.
Old 08-28-2012, 04:03 PM
bigzirb's Avatar
Ordered all of the wheel bearings and seals to rebuild 1 side of the front axle. Since I am converting it to 8 on 6 1/2 outers from a Dana 44 HD to make the front match the Dana 60 rear. I figured this would be a great time to rebuild everything. I only got 1 side cause it will probably be another few months before I got to the other side...
Old 08-28-2012, 05:11 PM
Edgethis's Avatar
Hope to finish installing teh new gaskets today. The Wife wants to learn how to work on cars so its going slow.
Old 08-28-2012, 05:40 PM
Yeah learning how to work on cars. Putting headers/gaskets on is the best place to start! I haven't done it yet, but i plan to use TGM today to help a friend and co-worker of mine move out of her apartment. Now that i can safely drive it, it is the only truck she knows up that can haul her bed and chair.
Old 08-28-2012, 06:16 PM
Captbs32's Avatar
Captbs32 Captbs32 is offline
Captbs32 is starting off with a positive reputation.
Figured out it needs u-joint(s) really bad. SWEEEEEEk
  #28
Old 08-28-2012, 10:07 PM
Aw man, u joints are never fun... Especially that double cardon joint.. What a pain.
  #29
Old 08-29-2012, 12:00 AM
bigzirb's Avatar
I picked up my wheel bearings from Auto Zone then got in trouble when I got home for spending too much time in the garage. I agreed to spend time with my wife and son in the house tonight. I made dinner, gave him a bath, and put him to bed. Then I sat on the couch with my wife while she watched her TV shows and I started typing up my build thread (finally) on the laptop while sitting next to her.
Here it is.
http://www.ford-trucks.com/forums/11...big-truck.html
At least that is the start, I'll keep updating it as I have time until I get it to where I am now.
Stay safe and keep working on those Bronco's!
  #30
Old 08-29-2012, 12:37 AM
pintoches's Avatar
pintoches pintoches is offline
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
Bigzirb, Already following your build,looks Good! Mine started out the color too.
Playing with the bronco today, Switched the vacuum advance from a ported vacuum on the carb to full time manifold vacuum. Found out the advance in the dizzy is bad. So that could be why it pops so much When I get on it?
Hope to find the other dizzy this weekend!
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-26-2016 12:18 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 02:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 03:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 07:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
