What did you do to the Bronco Today?
#243
Will do, i might end up just posting the stuff in my TGM thread since the truck isn't a bronco When i talked to them earlier, they said after the motor gets finished they are going to look at painting the cab and bed then re-assemble everything.
I can get closer pics some time, i don't know for sure what axles they used. They still have to get more parts and drivelines built.
That sucks, losing another bronco. But you have to do what you have to do.
#244
Finally got the new MOOG tie rod installed tonight, the one from the pitman arm to the passenger side. It cost me around $147. Still limping the M5 trans, got another 50 miles out of it today. 3rd gear is worthless, no longer stays in, and now 4th gear is going out, or not! The shift fork must be about worn completely out because I have to wiggle it just right to shift out of 4th. It may come down to pulling the tunnel cover to put another set of shift rails on it. A buddy of mine found a 2wd ZF for $150, how bad is it to convert to 4wd output if we can find the busted 4wd trans I let go last year?
#245
I let it go for $3000. Listed it at $3500 and just got tired of selling things. I broke even on it from buying, repairs, and use (10,000 miles in a year) so I feel ok about it.
It was a 93 EB, 5.0, 111,500 miles, new rotors and pads, front d/s u-joints, heater core, mirrors, headlight housings, alt., batt., belt. Ran great, needed EGR valve and front ABS sensors.
I did not really want to sell it but we need to stay at two vehicles....and the '11 Mustang GT/CS 5.0 is staying in the family for a while.
#246
#247
Welp, this is what I did...had to have it towed home. I think it threw a rod...Its something in the lower end. I just got done filling it at the gas station. I checked my oil, it was a little low...The dipstick doesnt fit snug in the block anymore. So it seeps from there. Added a little bit, only 2 miles from home. I figured it would also be a good time to recheck/re-adjust the timing. It developed a hesitation off-idle.
So I went to the empty side of the parking lot, loosened up the hold-down bolt for the dizzy, motor was at operating temp(180*F) Unhooked the vac advance and started it back up. As I was adjusting, I'd rev up the motor to see how it responded...I dont think it went over 4500rpm. I thought I had it where I wanted it, hit the throttle once more, and all of a sudden. A loud Bang and she started knocking...very metallicky sounding, I jumped off the truck and ran around to shut it off. But it stopped on its own by the time I reached the key. I seen it still had good oil pressure before I turned it off. Nothing leaking, nothing looked out of place. Started it up real quick and its knocking bad, but still showing 20-24psi at warm idle. Had about 100miles on this go around.
Im beyond mad at this point. Ive spent all this money on it and Ive have had nothing but trouble with it. It never gave any warning signs. motor was smooth and quiet as a church mouse. I was babying it the past couple days since I was DDing it. Trying to gauge what is was getting for mpgs. Im not sure what Im going to at this point.
Last edited by Boss351Bronco88; 10-31-2012 at 04:43 AM. Reason: spelling, grammatical errors.
#248
in other news, my bronco has developed quite a loud thump as I push the gas to drive, it seems like the drive line so tomorrow (hopefully) I will get under there and check it out, maybe grease the u joints. the weird thing is it only does it under a load... one thing after another.
#249
#250
Haha Brett guess what... It was the 4 12 point bolts on the t-case side all 4 were loose... The drive line was wiggly and binding up as it turned... Unfortunately there is only 1 u joint i can grease, the other ones i can't get to cause i probably screwed up or something when i did them . I am happy it was just that and not something worse. It's a good thing i decided to look at it or they could have broke.
Barely fits in the garage door.
#251
Sorry to hear that boss..
Dylan, that was a good move.. if you didn't do it.. maybe anew driveline? Lol
Wooo man.. its hecktik down here with all the trees and dwn powerlines..
Had 3 ft ofwater in my restaurant.. sheetrock destroyed... eh no ones hurt..
Its all good..
96 351 has a bypass pulley for smog pump.. the bearings were destroyed in it...
Bought new one with bearings.. for $10 at rockauto.. and $10 for spark plug ires..
Luckally my trucks weren't underwater except my 63 f100.. had water in the cab.. but no interior.. or body damage so it doesn't bother me..
Still no power in my house.. haven't had it since monday
Its all good..
#253
Thanks yall...Yea went up to the shop to talk with the owners. Brought a buddy to help me keep my temper in check. Basically I explained how mad I am, how dissapointed I am in their work so far, how this not only makes them look bad, but myself as well. I have people who rely on me for help on their cars. And when they see that I cant keep my Bronco running with all the money Im spending. Well, they second guess me and my abilities. It's not like Im getting anything out of it breaking on me.
They were upset and very apoligetic...promised me that they would rectify it as soon as I get the motor back to them. I appricaite the fact that they are honoring the work that they've done. but obviously this should not be happening. I dont think they would have managed to stay in business for almost 40 years if their work was shoddy. So fingers crossed that next time I around everything will be good and last.
#254
