What did you do to the Bronco Today? - Page 155 - Ford Truck Enthusiasts Forums
  #2311
Old 08-30-2014, 09:08 AM
gatorfor88's Avatar
gatorfor88 gatorfor88 is online now
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
Quote:
Originally Posted by GruesomeJeans View Post
I haven't done much, I bought a battery for mine so I can start trouble shooting. There was an interesting noise last time I ran the motor.
Was it a chugga chugga ping ping doodoo bebop noise or a baboomba baboomba bedinga dinga doodledump noise?
  #2312
Old 08-31-2014, 01:34 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Doodlebump .
Actually it sounded almost like a lifter tap. However, the oil is old and at this point probably low. My main concern at the time was getting it back in it's spot since it had been stuck in the neighbors driveway..
  #2313
Old 08-31-2014, 01:43 AM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
Figured out why my engine wouldn't start, had 2 wires turned around. Pulled the 9" form under it and am in process of installing the 10.25. That axle is a brute! and heavy too!
  #2314
Old 08-31-2014, 01:45 AM
Coil wires? That was my issue when I first got TGM. We tried to tune it and the coil wires had been cut and re-taped by the PO. One wire broke connection and that was the end. Cost me over 150 in guessing what part broke.
  #2315
Old 08-31-2014, 03:57 PM
jasoncarpenter1's Avatar
jasoncarpenter1 jasoncarpenter1 is offline
jasoncarpenter1 is gaining momentum as a positive member of FTE.
So I broke my pass side outter shaft while in a tandem pull. Great time to install the chromoly 35 spline shafts I bought a while ago.
All good now....................
  #2316
Old 09-01-2014, 10:02 PM
FourXFord2's Avatar
I got the 10.25 bolted up today and was working on new brakes when realized that I was missing a slack adjuster and the adjuster cable on other side is only half there. Also noted the park brake cables will not work. Back to the parts store.
  #2317
Old 09-03-2014, 10:16 PM
FourXFord2's Avatar
Getting closer! New park brake cables installed, new wheel cyliders,new brake pads,and new drums installed. Got tired of fighting those retaining springs so I made a tool from some 5/16 rod to help install. Works sweet.
  #2318
Old 09-04-2014, 08:55 PM
I fired up the bronco today, after about 3 months. I plan to drive it tomorrow night to work.
  #2319
Old 09-04-2014, 09:22 PM
FourXFord2's Avatar
I found some tires, wadda think? 9.5 x 16 BFG Silvertowns. Tires were free, tubes cost me $80.
  #2320
Old 09-23-2014, 12:39 PM
FourXFord2's Avatar
Pulled the '78 out of the weeds and. Got it running. 4tires, a lot of soldering to fix gas tank and new track arm bushings, just needs new wiper blades now.
  #2321
Old 09-23-2014, 07:28 PM
FourXFord2's Avatar
Got tired of smelling the rodent urine soaked paper glovebox so I removed it, pulled the staples and laid it flat. I wanted to use aluminm sheet but all I had was stainless steel. Traced the cuts onto steel and cut with zip disk and 4" grinder. Then I marked the bends and folded it up and secured it with stainless screws. Gound off the inside pointed end of screws, then installed it and marked and predrilled the holes. Reinstalled it and the door with more stainless screws.
Next step will be to find some felt to glue to inside to eliminate anything metal thrown in there from rattling. I made it to fit tight with no extra holes so now mice won't be trying to make their home in it anymore.
  #2322
Old 09-24-2014, 01:56 AM
Damn that's pretty awesome! I dislike the paper one just because Washington is kind of a rainy place so everything gets hit by moisture. Paper doesn't hold up well.
  #2323
Old 09-24-2014, 04:54 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
ya the oem one leaves alot to be desired
  #2324
Old 09-24-2014, 10:01 AM
Quote:
I would love to run a set of those just once.........
What do you think of them?? What kind of mud do you play in??
  #2325
Old 09-24-2014, 04:17 PM
FourXFord2's Avatar
I thought you'd like taht idea. JBG sells a plastic one too.
I haven't run the ag tread yet, still waiting on parts. My Bronco addiction forced me to start driving my '78 again. This time I have parts on hand to fix what needs fixing! Well most of them anyhow. Need to change the PS pump, I don't think it's doing it's job at all, also some steering stabilizes would be nice. It never had a coolant overflow tank so I took the one from the '94 F150 and made a simple bracket to mount it to the fender. Almost fell over backward when I discoverd the stock '78 pump connector was the same! Now I can save all the antifreeze that boils out. Tonight I need to find a reciever hitch and evict the mouse nest from the heater.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 01:38 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 12:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 01:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 02:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 06:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
