What did you do to the Bronco Today? - Page 153 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
  #2281
Old 07-15-2014, 09:22 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Can't wait to get my 79 back...ZF5/NP205 twin stick, Hydroboost braking system, saginaw pump, rear disc brakes, new 468....oh man....someone get me a towel.
  #2282
Old 07-15-2014, 10:32 PM
Deadsquiggles's Avatar
Deadsquiggles Deadsquiggles is offline
Deadsquiggles is starting off with a positive reputation.
Well, I dropped my bronco off at the mechanic yesterday to diagnose the stuttering or whatever you wanna call it. He called back today and the cats are clogged up and it's forcing the exhaust to try and travel backwards. So now I need new cats. I'm not sure how many are on these trucks, but whatever happens, I figure nows a good time to run dual exhaust.
  #2283
Old 07-16-2014, 02:38 AM
blackjack33's Avatar
blackjack33 blackjack33 is offline
blackjack33 is gaining momentum as a positive member of FTE.blackjack33 is gaining momentum as a positive member of FTE.
Installed a new fuel pump and soft lines.
Didn't fix the problem...probably have to drop the tank.
  #2284
Old 07-17-2014, 10:01 AM
I should be picking it up today. Two new cats, new y pipe, and a new Super 44 muffler getting put on.
  #2285
Old 07-22-2014, 11:46 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
Finished running all of the accesory wiring. The lights on my Lund visor work for the first time since I owned it. Evicted a wasp nest from the visor,wife noticed it before I bumped it. had yo be 4 inchces from it at one point! Glad they were in lazy mode. Solenoid and actuator switch are wired as well as wiring for future front air locker. Fixed the tear in the headliner, sewed it with some thread for now. It should hold till I can get some new material.Run new spedo cable and installed the VSS on t-case. No plug for the 4X4 indicator on the 205. Oh well, I could rig some micro switches near the shift rails if I wanted to.
I can't wait to test this thing on a trail!
  #2286
Old 07-23-2014, 08:23 AM
FoxFord33's Avatar
FoxFord33 FoxFord33 is offline
FoxFord33 is starting off with a positive reputation.
congrats, man! Sounds like it's coming together.
  #2287
Old 08-01-2014, 10:57 PM
FourXFord2's Avatar
Again the wiring stops me. I have 2 wires on the engine side to connect, no idea where they go. I ended up using a 5.8 harness pulled from a '90 F250 that was scrapped. I had saved all of the wiring from EEC forward.
any hoow I'm not sure where to run the orange wire and a red wire with a broken blue stripe. Orange wire appears to be grounded the engine block. and not conected directly to any other wires. I don't feel like pulling the harness apart to trace it out.
Another wire that is confusing me is a lt blue/yellow stripe on the '91 side of the harness. It can be seen here.
The other wires not traced out to source yet are white/pink, and a yellow/red. These 3 are on the '91 harness.
  #2288
Old 08-03-2014, 09:32 PM
MadMatt65's Avatar
MadMatt65 MadMatt65 is offline
MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.
Well.....after a "Bronco" hiatus.......I figure it's time to get back on track. Decided that even though one ton drive train would be really cool.....getting the Bronco back on the road would be SO much cooler!!! I feel I've fallen prey to "Gee!!! That would be so cool in my truck syndrome!" I HATE when that happens!! (I think that's the kid in me!) How easily we are distracted!!
Anyway, I got under the Bronco and noticed that the rear seal didn't quite look right...so I replaced it again with a little bit higher quality one. I saw one of the freeze plugs on the back of one of the heads looked a little "funky", so I knocked it out and replaced it. I noticed that the engine has been out before, or at least apart. New oil pan, intake and head gaskets. I'm thinking maybe a short block???
Found a Dana 44 in a 79 Bronco. I've got dibs on anything I need out of it. Then a friend called me and told me he has a Dana 44 out of a 78 Bronco!! I guess I'll pick the better one. Calling a tranny shop tomorrow morning and gonna get my tranny to him.
  #2289
Old 08-04-2014, 12:27 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Sounds like good progress. More than ive done, I've been filling the cab with junk. Ive got 2 bumpers and 2 slider windows for the top. However, I don't even think I want them anymore. I've sorta, changed my decision.. I would rather have a soft top. I know a place that makes them.
  #2290
Old 08-05-2014, 08:45 PM
I didn't do a thing to my Bronco today. I'd planned a trip to the car wash today, needed the pressure washer...that didn't happen.
Quote:
A local place? Send me the info if you'd be so kind.
  #2291
Old 08-05-2014, 10:54 PM
FourXFord2's Avatar
I opened the hood, poked at a few wires with the DVM then banged my head on the grill gaurd repeatedly in frustration! Well not yet but it's getting to that point. I did find out that the red with blue dash is tied into the dk green/ yellow which is the SPOUT and IDM wire. I think that relates to the white/ pink wire on the '91 harness. I am going to write up the wiring on the '91 F150 at work, and try to find a '90 F250 with the 5.8 as well. Also searching for something better then the Haynes wireing pictures.
  #2292
Old 08-06-2014, 01:58 AM
I wish, they are based out of New York. They make a tonneau cover type thing. I'll have to find the site but I can link to you. I wish they were here they need a 78 bronco to use as a "model" to make the tops for 78-9.
EDIT: here is the link http://www.aro2000.com/bronco_camper.htm
Its a "Fastback" style top. I kind of like the way it looks.
  #2293
Old 08-07-2014, 12:17 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
I finally took the pile of stuff that had been stacked on the engine off and realized how much work I have left to do. It is a bit depressing. I'm off next week to install some flooring in the house so i hope to get done quickly so I can give the Bronco some love.
  #2294
Old 08-08-2014, 07:30 PM
Fordman96 Fordman96 is offline
Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.
EDIT: here is the link bronco tonneau
I know what place you are talking about, but I'm drawing a blank on the name. I know for my 96' it's like $1,200 without the rollbar that holds the top.
I thought JBG sold them for the 78/9?
  #2295
Old 08-09-2014, 01:32 AM
Washed, clay bar'd, cleaner wax'd & hard wax'd the entire truck...polished the wheels x5.
Still not done, tomorrow I'll work on the inside, vac & detail & dress out the rubber.
Now, kickin' back, surfin' the interwebs, & enjoying a cold one.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-26-2016 12:18 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 02:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 03:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 07:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
