What did you do to the Bronco Today?
#196
I pulled the rear diff cover and found out I have a sweet gear ratio of 3.07.
I just can't seem to catch a break with a 3.00 in the front and a 3.07 in the rear. I guess I will be changing both gear sets before I get to take it on the road. I don't know if a granny low 4 speed would help with a 3.07 and 40's. Although, if the 460 could get it moving I'm sure I could have a huge top speed. The tires would be the same as changing down to a 2.30 ratio for more top speed. LOL
#197
Well i am pretty sure i worked out my issue.
I was checking plugs and the back one on the passenger side broke. I when to break the plug loose and once i did i took the socket off and it kinda fell apart. I think it had been cracked and finally snapped when i took the socket to it. It seems to run a little better though. Eventually i need to replace all of them, they weren't fouled and not nearly as bad as this one but it has been over half a year since i replaced them.
#198
3.00s with 40s, i bet that isn't much fun though, even with a 460
#199
#202
I changed the oil, Adjusted the idle, And redid the timing. This time, setting it the right way, Last time,I left the vac advance on and didnt realize it lol. Now she's idling beautifully. HAs a Nice thump. Very rev happy, And she hauls some serious A$$ lol. I embarassed a G-body Monte Carlo last night....Also rotated the tires as well. Something Ill probably need to do often now lol. Ill try to get some vids up later on.
Last edited by Boss351Bronco88; 10-24-2012 at 10:06 AM. Reason: left out some info.
#203
#205
a pink diff cover? not my first choice of color but it would be interesting.
as for TGM its running better now that I fixed the one plug, I can see that I need to do the other 7 real soon. I also think the gap on the old.ones was too small. I did about .054 I think is the measurement and that side of the motor seems to be idling better when it's warm.
#206
so easy to get them out when you break the electrode off.. not when there broken off flush with the head..
Pink = support for boobies..
filled rear diff and no leaks so far
#207
Yeah, it's a 4-spd, part of the reason I got it, One of these will be fixed, and the other is parts, for now the blue and white one is the one I'm fixin... but I've got 3-4 trucks in front of the bronco's...
Thanks...
They were a factory sa front end, sas means the sa was swaped in at a later date...
#208
Nah it was easy to get it out, i don't know what i would do if it sheared of flush with the head.. I might cry or something.
That it is, The tires are half flat too, so Idk how tall it really is lol...
Thanks...
Thanks...
#209
I mentioned in a previous post that I have 5 Dentside trucks, and 2 Dentside Broncos.
Out of those seven 3 Dentside Trucks will be fixed, and 1 Bronco.
1 other Dentside frame will live on, (I'm doing a street/strip truck) and will have a dentside body on it, untill I have an older body to put on it (56 or older) meaning that I am only killing 2 to save 4 1/2...
