What did you do to the Bronco Today? - Page 13 - Ford Truck Enthusiasts Forums
  #181
Old 10-21-2012, 11:28 PM
Yeehaw1's Avatar
Yeehaw1 Yeehaw1 is offline
Yeehaw1 is starting off with a positive reputation.
Brought the new bronc home, pics tommorow maybe... 38x14.5x15 tires don't fit well on my trailer...
  #182
Old 10-22-2012, 12:10 AM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
14.5 wide tires are big...
  #183
Old 10-22-2012, 03:46 AM
ErrorS ErrorS is offline
ErrorS is starting off with a positive reputation.
I should be posting in this thread
Yesterday I replaced my driver's side door pins, cleaned out some of the inside and sprayed the inside panels of my rear fenders with rubber coatings, then tightened a seat bolt.
Today, I've run a few electrical tests on my EGR and sensor and EVR. I think I have my EVR's vacuum hose flipped.. also going to go tighten some screws in my door panels, possibly go with bigger ones and add silicon to them so they wont loosen.
  #184
Old 10-22-2012, 06:21 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Thats more than i have done.. I looked at my bronco and thought "Maybe i should work on it today" But got side tracked because someone called about my ranger... Eh maybe tomorrow or something haha.
  #185
Old 10-22-2012, 03:22 PM
Today I broke off a rear shock mount jumping it.. also popped out my driver side coil spring after a jump and had to put it back in on the trail.
Bent up my insulator washer so now that has to be replaced!
  #186
Old 10-22-2012, 05:33 PM
Sick.. you gotta show me some pics of that jump mr errors.
Um.. cut the cat off and welded a side exit exhaust right infront of passengers door.. before front fender.. sounds really good without mufflers lol
  #187
Old 10-22-2012, 07:01 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Went to the hardware store and bought two 5/16 fine thread lock nuts and put them on the clutch master cylinder. I need to take the pedal assembly out and paint all of the parts I welded and fabbed under there. Umm, tomorrow...
  #188
Old 10-22-2012, 08:35 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
I'm parking my truck inside my residences now, so I sleep a little better now. I parked outside in the street before, so it's an improvement.
  #189
Old 10-22-2012, 09:04 PM
Well I planned on figuring out my engine miss but mother nature decided it would rain today... I did get hot chocolate though
  #190
Old 10-22-2012, 09:32 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
Found a ZF to replace my M5-going-bad trans, bought a tierod to fix the steering, was given a pair of Air lift bags for rear springs and a used rear window. I am hoping to clear the garage this week and do 10 hours of wrenching on my '91.
  #191
Old 10-22-2012, 09:34 PM
Oh joy, air bags... Are you planning to use them?
  #192
Old 10-23-2012, 01:16 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
I did this on Sunday, just a few sections of video I threw together. It was fun youll see I went to fast over the bumps and everything in the back of my truck went airborn lol
Offroading in the Bronco - YouTube
  #193
Old 10-23-2012, 04:22 PM
well I finally did something today, I dragged TGM out of his hole and drove it. I went and dumped $50 into its tank so that I have gas to drive around in. as I checked out the miss I have, I pretty much can tell it is on the passenger side. I pulled the cap and rotor and cleaned the contacts then made sure the wires and posts on the cap were clean. So far that hasn't changed anything so next I plan to pull the 4 spark plugs on that side and see what they look like. That's about the only thing I can think of now.
  #194
Old 10-23-2012, 04:42 PM
wire brushed and painted rear section of frame.. Started to clean my rear end out.. LOL..
I couldnt believe the gear oil in the rear end.. It looked like someone stuck sealer on and put fresh oil in it.. and left the truck in storage for years... came out clean with nothing in it.. REMEMBER this was a plow truck.. i scraped the frame and cleaned up about 5 gallon bucket worth of rust.. + shattered driveshaft..
New side exhaust exhaust.. open manifolds no cats nothing..
  #195
Old 10-23-2012, 05:03 PM
Haha make sure your rear end is extra clean :P. I like the added not of "shattered driveshaft" it just sounds funny. I think if everything goes as I envision, I can clean the frame on TGM and get some paint or something on it. but how often do things go as planned...
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 02:38 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 02:19 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
No Regrets Bronco/ Cummins Bronco Build Oldironsfury 1978 - 1996 Big Bronco 1 09-07-2012 10:25 PM
2010 FTE Bronco Championship Round-8 Entry Thread. 76f350spercamprspeal Picture competitions 5 08-02-2010 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
