What did you do to the Bronco Today? - Page 11 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
  #151
Old 10-19-2012, 12:11 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Thats true. Need to save all the money you can get.
  #152
Old 10-19-2012, 01:31 AM
Yeehaw1's Avatar
Yeehaw1 Yeehaw1 is offline
Yeehaw1 is starting off with a positive reputation.
Quote:
Originally Posted by GruesomeJeans View Post
I may have figured out a way to do it. It would take a while to get one pic though. Here is a test, it's my mustang after I gifted it to my step brother. They got into a wreck when someone hit them head on.
Not cool, and that looked like it was a nice stang at one point...
(and do you know how long I've been looking for that dang hood scoop?)
  #153
Old 10-19-2012, 01:43 AM
You have been looking for a fake hood scoop? What for? I'm sure a vehicle in a junkyard has one. Too bad this one isn't around or i could let you have it. Since i didn't own it anymore my step brother had it towed to a junkyard.
  #154
Old 10-19-2012, 08:54 AM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
No way.. he towed it to a junkyard???
I would have fixed it..
new front clip
  #155
Old 10-19-2012, 10:08 AM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Quote:
Originally Posted by 1_ton_bronco View Post
I know how to do it.. i just dont want to spend the extra money if my front brakes work
I hope I missed something because this makes it sound like you are driving around with front brakes only. Please tell me that is not the case as it is not only REALLY dangerous, it is illegal and opens you up to a ton of liability if you get in a crash.
  #156
Old 10-19-2012, 10:19 AM
Lol I don't even have a license
  #157
Old 10-19-2012, 10:31 AM
Yeehaw1's Avatar
yeah, I have an idea to put one on a Toyota Mud Truck I'm building, and cut a hole in the hood under it, just to give a lil more airflow to the carb...
Haven't found one I like yet, other than the mustang one like you had...
that would have been awsome, and that would have probably been fixable (if there was no major frame damage)...
  #158
Old 10-19-2012, 01:53 PM
bigzirb's Avatar
In that case no worries. I have had several projects that got moved around the yard with only front or rear brakes. One even had no brakes so it was moved with other vehicles so avoid a problem.
I got the slave cylinder to my hydraulic clutch replaced and hooked up. It is the strangest feeling to have a clutch at last.
  #159
Old 10-19-2012, 02:04 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Fixed the lack of compression in one cylinder. Pulled the valve cover off and discovered the rocker arm popped off the push rod. Easy fix!
  #160
Old 10-19-2012, 03:12 PM
new front clip
It's was no longer my vehicle, and my step brother who drove it didn't know anything about cars. He told the insurance it was a GT and didn't know what GT was. Also, unless someone has an ever burning affection for the 4 eye mustangs with a 200 i6, it wasn't worth fixing. the amount of rust on it and the front clip being smashed into the front of the motor was a lot of work.
I see. Well it's too bad i don't know where it ended up, we have a few junkyards around here that it could have gone to. As for the damage, being that it was no longer our car we didn't bother trying to look for frame damage. The hood was jammed shut and you could see that the rad and core support were smashed into the front of the motor. The pulleys and brackets were all bent and crooked. It wouldn't have been worth the time.
  #161
Old 10-19-2012, 03:16 PM
Yea I have a nice 1200ft x 60 ft lot next to my offce building..
I have 4 trucks and a ford escrt.. I get to play with them on that lot
  #162
Old 10-19-2012, 03:18 PM
Ha lucky you. I barely have room for my ranger and bronco on top of the other 3 cars we have.
As for my plan to work on the bronco today... I kinda don't feel like dealing with everything being wet or it starting to rain while i am working. I will figured it out later.
  #163
Old 10-19-2012, 04:00 PM
This damn rain... I need new wndshield.. the guy who cameand put my f100 windshield in he said it would be like $120 installed with glass
  #164
Old 10-19-2012, 04:22 PM
$120 isn't too bad. I need to get one for my bronco eventually. It it wasn't so we out i would be fiddling with the bronco...
  #165
Old 10-19-2012, 04:32 PM
Yeah, just had one put in my Bronco a few weeks ago and it really wasn't too expensive. No where near what I thought. I think it ended up being $140 ($40 to fix a crack? Or $140 for a whole new one? Hrm....) and they came out and did it in my parking lot while I was at work.
It was sad to see the original glass go, but I sure don't miss the multitude of weather pits.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-26-2016 12:18 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 02:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 03:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 07:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
