What did you do to the Bronco Today?
#1606
I could get a new sensor but it's never worked since I got it. Reason being is this.
The plug is done for. I don't know if a new sender would come with a plug or not.
As for getting a new one, I can get a new one for about as cheap as $80 if I'm lucky. The JBG one is JUST a Prop valve, Mine is a combo valve of prop and metering.
Here is the one I saw.
1976-86 Ford Bronco Disc/Drum Brake Proportion Valve w/ Pigtail Wire Carolina Classic Trucks 1978-86 Ford Bronco-prop-valve
I could buy separate valves and instal them in line but that might cost more. If I could buy a brake warning sensor and the right plug for it, then I would consider that if it was cheap enough.
#1607
#1609
So I haven't found the sensor anywhere. The places that list them say they don't fit. I'll have to pull it eventually and take it to a sore to get a match, maybe another year/model will fit. As for a whole setup, as mentioned, I need the combination valve. I'd rather get this one to stop leaking than spend excessive amounts of money I don't have on a whole new one.
#1610
#1611
#1612
I get sick and tired of brake work, drums, disk, everything. It's all a pain and it's all costly BUT I love the S**t out of my bronco and I try my best to keep it safe and in good working order. Sometimes things don't work out the way they should but you play with the hand you're delt.
#1613
Got up a little early and started working on the ole Bronco. Got the A/C and P/S bracket installed. P/S pump and pulley installed. Started messing with the A/C compressor and tried to mount it without the nuts that were between the compressor and bracket. The compressor hits the bracket and is still too far forward (towards the front). Took the compressor to the parts store and compared it to 2 different makes of compressors............previous owner had wrong compressor installed......by whoever!! So, when i get everything else done and ready for the road......I'll have a new compressor and A/C hoses. Gonna try and get the new wires, cap and rotor installed today. I had ordered Ford Motorsport wires off Amazon but got an email they were on backorder. I got some MSD Streetfire wires, cap and rotor. Starting to cloud over now, so I'm going back outside!
#1614
#1615
Yea, the compressor was a little noisy, so I'm just gonna replace it. I just can't believe a shop would let something like that leave their shop. It wouldn't even fit the bracket without the nuts as spacers and was too far forward. (about 1/2") It is even "clocked" different than the ones I compared it to. Even the clutch and pulley was different. I can get some of this other stuff wrapped up. Maybe even get these nice JBA headers installed......
#1616
#1617
Well, the bronco saw it's first dose of offroading in a long time. I decided to treat my coworker to a bit of fun since he has been helping me with guitar lessons and things like that. There is a dirt hill down the road, probably 40-50' tall, kinda steep but not terribly bad. This was also a good chance to make sure my 2 lo works, so after it got nice and soggy with the rain we ran up it. I hit it hard and fast with the pedal mostly on the floor. We made it to the top with no problem and we tossed every bit of cargo I had all around. My guitar ended up on the floor and my tool box was all messed up.
I almost got us stuck though, the dirt was real soft and the top isn't flat so I had a hard time going anywhere. After a while of rolling back in neutral then moving forward in drive, I finally got us at an angle where I could relax a bit. After finding all my marbles and cleaning my shorts we rolled back down the hill and that's where the fun began. As soon as we were back on level ground there was a terrible sort of grinding sound. After shutting the engine off and looking around I didn't see anything out of the ordinary. After opening the hood however, I discovered my battery had dislodged itself and fell onto the alternator pulley. The fins dug out a nice groove in the battery casing. It also ate away about 1/4 of the way through my negative battery cable. After getting that back into it's rightful spot and making sure nothing else was messed up, I tried starting it. The radio would flash then nothing. I grabbed my trusty flashlight hammer and pounded on the negative cable under the alt where it grounds out to the engine. Then it spurred to life. Made sure it was back in 2 hi and that it moved without any issues and we went on our way.
I'll tell ya what, despite having a brake leak, these brakes work damn good. And, the ol' beasty will still kick ****. All in all we had a lot of fun even if it only last for 3 minutes, but if I were to do it over again, I think I would have taken it a bit slower going up and maybe gone up one of the 2 side trails vs the center one. I was going to have my co worker jump out and take a video of me coming back up it but after the rough ride up I decided against it.
#1618
What did I do? Decided not to sell her. I've got too much time and blood invested, not to mention money, to just sell it after these last couple of years. I am going to take the back seat out of it though, so if anyone is interested in a tan rear EB seat from an '85, let me know. My plan is to make this a huntin' rig, and the seat gets in the way of that.
#1620
Yeah, I think I just needed a trial separation for a few weeks. My problem was every weekend, I would look out the window, see it, and feel compelled to work on it in one way or the other. Now that I've had some "me" time, and bought a Grand Cherokee that's a little easier on gas, I think we're in our 2nd honeymoon.
