What did you do to the Bronco Today? - Page 105 - Ford Truck Enthusiasts Forums
  #1561
Old 08-15-2013, 03:31 PM
MadMatt65's Avatar
MadMatt65 MadMatt65 is offline
MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.
The sun is behind the clouds today (gonna be a stormy weekend!) and I figured I would start battling the annoying belt squeal I can't seem to get rid of. Started looking at the alignment of the belts and I noticed the A/C compressor looks like it is noticeably "forward' of the other belts. Looking at where the compressor mounts to the bracket, there is some hex head nuts between the bracket and compressor. Seems like that would bring the compressor UP, but not FORWARD. It obviously doesn't look "factory", but did Ford put some kind of spacers there originally? I'm wondering if the bracket that holds the power steering pump and A/C compressor might be mounted wrong. It's not loose, but I believe has been removed by some prior owner. Any adjustments???
  #1562
Old 08-15-2013, 05:38 PM
MadMatt65's Avatar
Upon further study....power steering lines up....bracket is installed ok. If I line up the compressor where it lines up with everything else....it's almost 1/2" out!! I see the compressor has been replaced before, but now I'm scratching my head! I know there are clutch shims, but there is only about an 1/8 inch between the clutch and the compressor housing bolts. Hmmmm.......
  #1563
Old 08-15-2013, 10:27 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
I bolted the crappy little tires on the front axle and put it on the ground. It is off the jack stands for the first time this year! Too bad I'm months from driving status.
Nothing happening to the Bronco for the next few days as I will (hopefully) be swapping out the front springs on my Excursion if it doesn't rain all weekend.
  #1564
Old 08-15-2013, 10:29 PM
MadMatt65's Avatar
Pretty sure I have the correct compressor. It is the FS10...from what I read, that's the compressor that comes with factory A/C Broncos. In moving the compressor around.....the line started leaking. So, I removed it. Previous owner has changed the water pump and the timing cover. Why they changed the timing cover.....I don't know. There was nothing wrong with it. I've got the mounting bracket with the P/S pump off. I figured I might as well get ready to get the steering gear out as well since it has to be changed. Anyway, I'm thinking that when they changed the water pump and timing cover....they missed something going back together. Maybe a shim or spacer where the bracket mounts against the locating stud at the water pump. I'm thinking if I shim that out a little....it will bring the top of the bracket back where it needs to be.........I think!! I guess I will find out when reassembly starts!
  #1565
Old 08-15-2013, 10:58 PM
ronjeremy6's Avatar
ronjeremy6 ronjeremy6 is offline
ronjeremy6 is starting off with a positive reputation.
Ok this is pretty comical. When I bought the truck the driver door didn't lock, windshield leaked and slip yoke was dry. Finally of around to greasing the slip yoke last Sunday.
It rained all day Monday and Tuesday. The windshield didn't leak a drop.
Yesterday I walked past the truck and noticed the driver door look pin was missing. Ran back in, grabbed the key fob, hit unlock and it popped up! Door locked and unlocked yesterday and today!
I can't explain it , but I'm a happy guy!!
  #1566
Old 08-15-2013, 11:12 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
I love me a self fixing truck.
  #1567
Old 08-16-2013, 01:10 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Sat on the Bronco, warmed the engine out, tried to get off my parking spot and found out the front bearing that was bad finally failed, backed the truck up and took the public transport... I plan on replacing the bearing first time in the morning tomorrow, that and the brake pads, they seemed pretty worn the last time I looked.
  #1568
Old 08-16-2013, 09:45 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
was not a appy trip ome! Keyboard is malfuctionin so bear wit me
wen coastin down a ill te trans slipped out of 3rd and bronco suddere and died, Put it back and let of te clutc and it started bak up, but sounded wron , enine lite came on, no oil pressure or very little, I putted te rest of te way ome wit te lifter rattlin, Now ave to fiure out wat appened!
  #1569
Old 08-16-2013, 10:31 PM
Lemme give you a hand here
Quote:
Originally Posted by FourXFord2 View Post
Was not a happy trip home! Keyboard is malfunctioning so bear with me.
When coasting down a hill the trans slipped out of 3rd and bronco shuddered and died, Put it back and let of the clutch and it started back up, but sounded wrong, engine light came on, no oil pressure or very little, I putted the rest of the way home with the lifter rattling, Now have to figure out what happened!
There ya go , it appears you are having issue with you're G and H keys.. Bummer. The engine dieing is very weird. How was the temp when it died?
  #1570
Old 08-16-2013, 10:35 PM
Encho's Avatar
Oh man, your keyboard is a comedian
This is hilarious!.
  #1571
Old 08-17-2013, 05:03 PM
gatorfor88's Avatar
gatorfor88 gatorfor88 is online now
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
Well I was going to do ball joint,spindle bearing replacement today but in sunny Florida today we have had 4+ inches of rain already. I do have a carport to do it under but it aint no fun in the rain anyhow.
Oh well, it's not a do or die situation so it'll wait. Might as well have a Budweiser
  #1572
Old 08-17-2013, 05:26 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
cant you train them gators to do it?
  #1573
Old 08-17-2013, 05:34 PM
gatorfor88's Avatar
I tried that but they drank all my beer and stole my Bronco.
  #1574
Old 08-17-2013, 05:35 PM
Skip1970's Avatar
turn um into belts!
  #1575
Old 08-17-2013, 07:40 PM
Quote:
Originally Posted by b-uno View Post
turn um into belts!
I need a new belt.. Mine's about done for .
I'll get around to looking at my brake leak at some point... Lazyness gets in my way.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 02:38 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 02:19 AM
tbear853's 1977 F150 Brake Upgrade tbear853 1973 - 1979 F-100 & Larger F-Series Trucks 51 01-09-2017 12:00 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
2010 FTE Bronco Championship Round-8 Entry Thread. 76f350spercamprspeal Picture competitions 5 08-02-2010 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
