What did you do to the Bronco Today? - Page 104 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
  #1546
Old 08-06-2013, 06:13 PM
ZombieSlayer's Avatar
ZombieSlayer ZombieSlayer is offline
ZombieSlayer has a good reputation on FTE.ZombieSlayer has a good reputation on FTE.
Ok so I did this yesterday but wasn't in the mood to post.
Took Bronco to shop to get passenger window motor/regulator installed. Perhaps next time (drivers side is failing) I'll try it myself first.
Installed striker bushing so my door doesn't rattle anymore.
Went to the school to get my parking permit for the next semester, broke the pos interior door handle completely off trying to get out. Man was I pissed. Went to the dealer after trying the 3 auto parts stores in town and found a replacement for twenty two bucks. The parts lady (been there for 34 years now ... awesome lady very "Ford smart" ) says she has a couple dozen in stock because it happens a lot and keeps getting asked why there isn't an aluminum replacement.
So went to a couple of fab shops and got quotes ... and got discouraged. Sure gave me an idea for when I have the cash to completely go through the truck though
So while removing the door panel to replace the handle I notice the window/lock switch screw mount was busted (was wondering why the screw came out so easily) So now I either live with a loose switch assembly, or troll the graveyards in hopes of finding a grey interior drivers door panel in decent shape
  #1547
Old 08-06-2013, 06:24 PM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
I am the NRA and I vote
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
2 part epoxy and some fiberglass mat will do wonders repairing broken parts. Just dont go overboard with the epoxy.
  #1548
Old 08-06-2013, 06:30 PM
Quote:
That was my initial thought as well ... but I couldn't find the missing piece(s). Both switch assemblies (driver / passenger) are broken where the screw mount is/was
  #1549
Old 08-06-2013, 08:33 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
... JBWeld. Just glue everything
You could live with the loose switch till you get time to scour the junkyards for the panels.
  #1550
Old 08-06-2013, 09:08 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
I cleaned up a pile of crap in the yard so I could find the 2 other small tires for the Bronco. Now I can make it a roller again for the first time in almost a year. Hope I get some time to work on it next week. It is busy at work this week.
  #1551
Old 08-09-2013, 02:22 AM
I blew out the front driver side speaker today Also washed the Bronco but forgot to put battery in charge bay so no pics yet. Battery is in charge bay so I should have pics tomorrow
  #1552
Old 08-09-2013, 06:37 PM
gatorfor88's Avatar
Had a friend of mine give me an on-board air compressor this morning. It came off of and old coca cola truck and should be very high capacity, Even came with some brackets I may be able to adapt to fit. Just have to figure out some way to install a pressure switch or maybe put a/c compressor clutch/pulley on it. That would probably be best way to go so it wouldnt be drawing h.p. from engine unless it was turned on.
  #1553
Old 08-09-2013, 09:07 PM
bigzirb's Avatar
I messed up two of the fittings while working on my front brake lines so I decided to stop for the night. Getting older I've learned to pay attention to the signs that tell me I shouldn't do something.
  #1554
Old 08-09-2013, 10:11 PM
Quote:
Ouch, how'd you do that? I've come close to stripping some of those soft metal nuts... Not being able to find out line wrenches gets a guy desperate.
  #1555
Old 08-12-2013, 07:47 PM
bigzirb's Avatar
After having several problems with the fittings and adaptors I was trying to use for my front brakes I gave up. I went to the parts store and picked up new flex hoses to attach to the front calipers. This will allow me to do all of the front brake lines tomorrow with the rest of the parts that I already have, I hope. If I get th brake lines done It will be back to working on the clutch problems.
  #1556
Old 08-12-2013, 11:15 PM
Installed new speakers on the doors since I blew out the drivers side a few days ago.
  #1557
Old 08-13-2013, 09:01 AM
Boss351Bronco88's Avatar
Boss351Bronco88 Boss351Bronco88 is offline
Boss351Bronco88 is gaining momentum as a positive member of FTE.Boss351Bronco88 is gaining momentum as a positive member of FTE.
Finally fixed the 4wd on mine. the linkage would not line up right. So if it was all hooked up. it would never go into 2wd. And it would constantly pop out of 4hi. So as I was cleaning up the underside of the truck this past weekend. I started messing with the linkage. I was able to loosen it up and line it up correctly. Now everything works like it should...Finally lol. Threw the front driveshaft back in. Installed New Header collector hardware, degreased the front suspension, underside of motor and trans. under body. scrubbed and scraped all the crap I skipped before lol.
  #1558
Old 08-13-2013, 02:05 PM
harleydeen98258's Avatar
harleydeen98258 harleydeen98258 is offline
harleydeen98258 is gaining momentum as a positive member of FTE.harleydeen98258 is gaining momentum as a positive member of FTE.
It's been awhile, but got the '93 Bronco running and registered so after replacing the TPS and MAP sensors I'm taking a coffee break and going to replace the coil and wires...just thinking I might try those accel wire sets for the first time...
  #1559
Old 08-13-2013, 04:53 PM
gatorfor88's Avatar
Installed 2 new door lock cylinders today. Now I only have 2 keys to unlock everything. I am waiting on an answer on a company in Texas on whether they have a new cylinder that operates rear window in tailgate. Hopefully they do so I can finally fix rear window. That will be 1 more thing to mark off the list.
  #1560
Old 08-14-2013, 09:19 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
Didn't do a darn thing to it. I did score this little number though.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-26-2016 12:18 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 02:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 03:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 07:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
