What did you do to the Bronco Today? - Page 101 - Ford Truck Enthusiasts Forums
  #1501
Old 07-22-2013, 10:18 PM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
Proportion valve
  #1502
Old 07-23-2013, 02:19 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Quote:
Originally Posted by Encho View Post
Proportion valve maybe?, it does seem wet.
Quote:
Originally Posted by 1_ton_bronco View Post
Proportion valve
Is that what it is? I figured it would be up built into the Master or something. So with this looking the way it is, would it be wise and cost effective to replace it? I need to clean it with some brake cleaner then let it dry and refill/bleed the brakes, then check on it to see for sure. If that's the case I will have to look at a replacement.
  #1503
Old 07-23-2013, 10:42 AM
Nighteyez's Avatar
Nighteyez Nighteyez is offline
FTE NorCal chapter LDR
Nighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputation
Used one of those headlight lens polishing kits to brighten up the headlights.
Before
And after, looks like the passenger side could use a little more polishing.
Jim
  #1504
Old 07-23-2013, 11:44 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Quote:
Before
Jim
I read somewhere about using a clearcoat on plastic headlights, taillights, etc. Here are a couple of links.
How to restore plastic headlights
headlight restoration (also good for taiollights, marker lights, etc...)
I think the clearcoat thing would both look and last much longer. But you're doing a fine job too.
  #1505
Old 07-23-2013, 03:58 PM
I think I read about that Dave. Though I thought I remembered reading that it didn't help a whole lot for some reason. like the clear wouldn't stay on the lights or something.
  #1506
Old 07-23-2013, 04:04 PM
Grubbworm's Avatar
Quote:
I read that in there too. The guy said it was because the lens wasn't clean enough or scratched/ sanded enough in the spot where it was peeling. He also said that too few of them came back for him to change the way he prepped them. I think it was something like 3 returns in 10 years of doing them. I'm going to eventually do my taillights and markers when I finally get to that part with my truck, but I've got a long way to go.
Here's that link to that article. http://www.spiuserforum.com/showthre...ight=headlight
  #1507
Old 07-23-2013, 05:06 PM
Yeah that's right. I guess if it's prepped right it will be fine. I've got glass sealed bulbs for my Bronco and plastic lenses. I'm not super worried about the lenses fading though.
  #1508
Old 07-25-2013, 02:21 PM
MadMatt65's Avatar
MadMatt65 MadMatt65 is offline
MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.
Finished the "HEATER BYPASS MOD" (thanks Bubba!) Got a little worried when I hooked up the vacuum, and nothing happened!! Found the vacuum leaks, multiple trips to different parts stores....(Thanks SO MUCH Autozone!) Anyway, got it finished up and repaired multiple vac leaks and now I'm chillin' like a villain!! Now on to more projects on the list!
  #1509
Old 07-25-2013, 06:21 PM
The other day I was fiddling around with my bronco and after filling my brake fluid back up, I decided to diag my vacuum leak. Turns out my Intake gasket is shot on the driver side. It's a small vacuum leak and I'll probably temporary seal it with RTV or something but it will get fixed when I can afford gaskets. I would like to get some nicer ones. The ones I got were kinda cheap. I'd also like to enterain the idea of actually getting gaskets for the front and back of the intake. When I put it together I just used a lot of RTV and it's messy.
  #1510
Old 07-25-2013, 08:07 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
I was elbow deep in wiring issues on my Excursion today so all I did to the Bronco was look at the new parts that arrived. My rear brake calipers arrived today along with the new master cylinder. Still waiting on the booster and brake line fittings so I can start making brake lines and bolting parts on. Too bad I work 12 hour days the next 3 days so I won't get to do much until Monday. I might get them prepped and painted this weekend if I'm lucky.
  #1511
Old 07-25-2013, 09:01 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
I'M SOL ON GETTING A MOTORCYCLE! BLAH!
Got to deal with the gas guzzling!
  #1512
Old 07-25-2013, 11:31 PM
Gas guzzling is a way of life! I put $25 in TGM from E and it got just above 1 quarter tank. I hope it gets me to the WAFTE truck meet this weekend.
  #1513
Old 07-26-2013, 08:49 AM
kennyds79's Avatar
kennyds79 kennyds79 is offline
kennyds79 is starting off with a positive reputation.
Looked at it longingly and hoped that "life" would afford me some time in the near future to be able to do SOMETHING, ANYTHING to it.
  #1514
Old 07-26-2013, 12:29 PM
Quote:
You ain't about the kick the bucket are you?
  #1515
Old 07-26-2013, 12:41 PM
Encho's Avatar
Encho Encho is online now
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
I think he meant he's swamped with other occupations.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 02:38 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 02:19 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 01:13 PM
No Regrets Bronco/ Cummins Bronco Build Oldironsfury 1978 - 1996 Big Bronco 1 09-07-2012 10:25 PM
2010 FTE Bronco Championship Round-8 Entry Thread. 76f350spercamprspeal Picture competitions 5 08-02-2010 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
