Fuel Pump Issue - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Fuel Pump Issue
Old 08-22-2012, 01:12 AM
joelsbronco joelsbronco is offline
joelsbronco is starting off with a positive reputation.
Fuel Pump Issue
For some reason these last 2 months my fuel pump has its on and off's. I just put in a new engine and transmission into my bronco, and since then my fuel pump has been acting up. I put a new in tank one in 3 years back, but now there are times where it doesnt turn on when starting the car. I'll go underneath with a stick and tap the fuel line and electrical piece leading into the tank and then the fuel pump will turn on. I wanna fix the problem so i dont have to worry about doing that anymore. Could it be the inertia switch? fuel pump relay? or is their some electrical wiring going bad? All i know is it never did this til after the new engine and tranny came into my car, and i have to tap the lines for it to turn on.
Any solutions???
Old 08-22-2012, 10:26 AM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
Yes, yes, and yes. That said, since it seems to respond when you tap things back by the fuel tank, the inertia switch (located near the passengers feet) and the relay (located under the hood near the passenger fender) don't seem as likely as some loose connection in the wiring near the fuel pump.
Fuel pump circuit is a pretty basic DC circuit. Next time it won't start, get a wiring diagram and a voltmeter and see if you can locate the break in the circuit.
Old 08-23-2012, 02:22 PM
Ok. Do you think it could even be that the ignition is not making contact to the wiring going back? It does make contact with the starter when it doesn't want to turn on so that's all good, but then I tap the lines then it turns over and we're good. Idk just a thought. Maybe the problem not in the ignition not making contact with the wiring going back?
Old 08-23-2012, 03:54 PM
Not entirely certain how to interpret that post. In an indirect way, the ignition switch could also be at fault. The ignition switch causes the EEC relay to close, which powers the PCM and the rest of the engine management system. The PCM decides when to command the fuel pump relay to close. So, if you determine that the reason the fuel pump isn't running is because the fuel pump relay isn't closing, part of the diagnostic tree at that point will be to check if the PCM is sending the signal to the fuel pump relay to close. If not, then one possibility is to check that the PCM has power, which could eventually lead back to the main ignition switch.
Old 08-26-2012, 11:02 AM
gilbee gilbee is offline
gilbee is starting off with a positive reputation.
I had the sme problem
OK.. i see where the other guys are right but also I did all the same steps..
I found out that my broncoII had two pumps. one in the tank and one on the drives side on the frame near the wheel well. first thing yu need to have done is a pressure test to make sure there isnt a clog in the line somewhere and then if so I recommend the filter ( you prob already checked that). then if the problem continues check f you have the two pump system. change the front one first ( it's pretty simple) and recheck .. then if you have to ( i hope you dont) you mght haveto change the pump inthe tank. ( that is a lengthy pocess, make sure you ae in a well ventalated area) change out the tank pump. Get the full set of rings and gaskets not just the pump..
good luck.....
Old 09-20-2012, 03:09 PM
old boxer old boxer is offline
old boxer is starting off with a positive reputation.
it`s back there at the tank,my friend
Old 09-20-2012, 11:50 PM
And that fuel pump in the back is fairly new at 3 yrs old. My old one lasted 20 yrs
Old 09-21-2012, 08:40 AM
i think your problem is at the wires to the pump in the tank, you say when you tap the wires with a stick at the tank she starts up. so that sounds like a connection problem to me. good luck hope you get back on the road.
Replace fuel pump without dropping gas tank Jymmm Expedition & Navigator 19 09-08-2016 12:53 AM
Fuel pump question 08gasurveyor 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-06-2013 04:48 PM
Fuel pump/filter/pressure regulator questions. Myfreeford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 01-11-2012 11:07 AM
2004 Ford Ranger Tremor Fuel Pump Problems or Someting Please Help!!!! dffdixie Ranger & B-Series 19 09-11-2009 12:02 PM
Electric Fuel Pump Safety HT32BSX115 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 13 01-03-2008 02:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
