I beam swap - Ford Truck Enthusiasts Forums
I beam swap
Old 08-22-2012, 12:04 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
I beam swap
Does anyone know if you can swap the old king pin I beams for the newer style I beams that have adjustable ball joints? Or, how do you align the older I beams?
Old 08-22-2012, 12:17 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Dunno about newer beams with ball joints but the kingpin style i-beams are "aligned' (ahem, "bent") using braces, chains, and a bottle jack... it's quite ...ummm.. what's the term?... Aha.. "primitive".
Old 08-22-2012, 04:09 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
Quote:
It doesn't need to be anything but primitive. Once set an I Beam suspension almost never needs reset (camber or caster). If so it is an indicator something is bad & needs replaced.
Old 08-22-2012, 11:56 AM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Yeah - not primitive at all, but rather closer to a "real" truck = big truck. Just not super practical anymore... Kingpins are much stronger than ball joints & wear out much less.
To answer the original post - no, newer beams are NOWHERE near a bolt in swap.
To align you'd need to have an old school alignment shop or big truck alignment shop check the thing & do the work.
What is the truck doing that it needs an alignment? Tires pointing in at the top (bad camber) due to coil sag? Or you trying to lift/lower it or what?
Old 08-22-2012, 01:44 PM
HIO Silver's Avatar
It's primitive in relative terms given today's technology... like using a hub-mounted bubble gauge versus lasers and mirrors for alignments.
Old 08-22-2012, 02:19 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Old 08-22-2012, 02:52 PM
HIO Silver's Avatar
Okay, shackles.
Lemme grab a cold one from the ice box, fill 'er up with Ethyl, and dial the rotary phone.
Old 08-22-2012, 03:47 PM
I'd gladly have someone who had the knowledge to align one of these trucks work on mine rather than the $6/hr kid most of todays alignment shops have work on it. They throw the thing on the rack, make sure the computer says "it's good" (more like - eh, it might work) and they scoot you out.
I'll take stronger over easier just because in most cases.
Halo projector lighting Bishop1986 1997 - 2003 F150 5 09-20-2016 08:03 AM
I beam swap Dean6586 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-18-2015 02:49 PM
94 F250 I-beam bushings 94 F250 supercab 1987 - 1996 F150 & Larger F-Series Trucks 26 12-23-2011 03:25 PM
High & Low Beams Simultaneous BAJI26 Excursion - King of SUVs 27 02-28-2011 10:24 PM
drop I beams....... williamwilliam 1967 - 1972 F-100 & Larger F-Series Trucks 14 10-03-2003 04:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
