Starting my 76 Highboy DT360 swap
#106
#107
#109
From what I know the only clutches that work right now are custom made.
It's a billet flywheel twin disc, so I guess if you need a clutch/flywheel it won't be cheap but shouldn't have to worry about not getting one.
Looks like they updated the website and have the conversion parts listed.
CSD DT360 Adapter Plate ? Carson Stauffer Diesel Performance
#110
#111
#112
Sweet build. I put a DT466 in my 71 IH Travelette and am working on a DT360 in my 91 F350. You probably got the adaptor plate right before I ordered mine. That's the only thing I'm waiting on right now. And I noticed someone said about the steering pressure relief valve. Everyone I've talked to said you can hook the DT pump right to the Ford box with no problem.
#113
I haven't been getting much else done because I've been working on other projects. That and I've been trying to find another highboy frame to build a work truck with the Dt and wait to build the crew when I find another Dt.
I ended up selling the 7.3 to make up some money for another project, so I'm not sure on what radator I'm going to use but the intercooler will either be a Cummins or aluminum 7.3 unit.
I'm going to be using a highboy divorced transfer case which has the speedometer on it's output, so I'll be able to run all Ford parts for the gauges hopefully.
As for shaving the oil pan it shouldn't be a problem with the new trans adapter and I plan on a small lift for clearance between the axle and pan.
That travelette sounds like a badass rig and that's good news about the steering setup. Should help avoid some headaches anyway.
#115
