Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
350 VS 352
Old 08-21-2012, 03:29 PM
Frankinstine's Avatar
Frankinstine
Frankinstine is offline
350 VS 352
In a towing situation which on would pull better up a hill with matching transmitions and rear end gears. The bore and stroke on the motors are almost exact. The 352 has a bore of 4.000 and stroke of 3.500 and the 350 has a bore of 4.000 and stoke of 3.480. I would think the ford because I like it better but that is just me.
Old 08-27-2012, 07:05 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,588 Likes on 1,294 Posts
Stock, the Chevy wins. The FE has terrible exhaust manifolds. Other than that, they are mostly the same, with the 350 obviously getting modern upgrades towards the end of it's life which would put it ahead of the 352.
If you found the last 352 in '67 and pitted it against the first 350 in '67, it would probably favor the 350. If you pitted the weakest versions ever offered, the 352 probably wins as it did not suffer the 1970s horrors. If you pitted the hottest stockers ever offered, the Chevy wins.
If you reenacated WWII using all available 352s vs. all available 350s, the Chevy wins......
If you go wildest aftermarket build, the 352 probably wins as you can overbore it to 4.050 and stroke it out to a 438, just a little larger than the 427 a 350 will go to.
Old 08-27-2012, 09:00 PM
dkf's Avatar
dkf
dkf is offline
If you have a Chevy/GM put a 350 in it. If you have a Ford put a 352 in it. If you put a 350 in a Ford and a 352 in Chevy/GM I hope they both blow up.
Old 08-27-2012, 11:18 PM
85e150's Avatar
85e150
85e150 is offline
Not what he asked.
Old 09-03-2012, 05:35 PM
less's Avatar
less
less is offline
The 350 was a small block...the 352 FE was a big block....having said that...is there much of a difference between BB and SB....nowadays not even displacement.
Back to the question...I think the FE series is more comparable to the Chevy BB of the time...the W series ie; 348 and that real fine 409.
Not sure if there would be much difference between a 348 and a 352...although the 348 rumour has it, was originally designed to be a MDT and HDT gas engine.
Old 09-03-2012, 11:21 PM
85e150's Avatar
85e150
85e150 is offline
In '58 to '61, you would compare the 352 to the 348. Except for a '60 version, the 348 outpowers the 352 in the higher performance versions, so they say:
Chevrolet Big-Block engine - Wikipedia, the free encyclopedia
FE Series Engine Specification Chart
Compare the 409 to the 390 and 427. Things even out against the 427 and the 427 went on to be the clear "winner" historically. (Le Mans comes to mind)
Comparing the 352 to the 350 isn't a good comparison as the 352 was done when the 350 was intro'd. Being that it built on the already successful 327s, it is the clear "winner".
Block size does not matter in these comparisons.
Old 09-03-2012, 11:30 PM
smokenchoken's Avatar
smokenchoken
smokenchoken is offline
personally i would go 352 i have used both 350s and 352s both are good at what they do and my 352 always did better on gas than any 350 my family has ever owned
Old 09-04-2012, 11:41 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
There are so many possible variables here that this is an impossible question to answer. In general, talking factory stock, Chevy head breathe better. That means more total peak hp. There is no way for a stock 352 to overcome that limitation. However, if your tow rig is handicapped with a numerically low axle ratio, say 3.08, the 352 may have the edge, due to smaller valves leading to higher velocity leading to a lower rpm torque peak. This, of course, also depends on the stock cam grind.
Things like bore/stroke and rod ratio are great talking points, but those theories seldom pan out in the real world were there are so many other factors involved. Both long stroke and big bore engines have been made into torque monsters. Aircraft engines typically produce peak power below 3000 rpm are extremely oversquare, for example.
cartef
03-01-2010 06:08 AM
customdavez
06-04-2009 08:16 PM
Grey89F250
16
03-16-2008 08:57 PM
hrtims
01-14-2005 06:19 AM
400Nut
06-20-2004 10:16 PM
Quick Reply: 350 VS 352
